Hi Team,
Can you please help us to create customize performence dashboard for a particular host group.
I mean in a single dashboard, For a number of host -CPU,Memory etc graph will show.
Create customize performance Dashboard
Regards,
Sk Abdul Goffar
Nagios Version:Nagios XI 5.4.8
OS:CentOS release 6.5
Sk Abdul Goffar
Re: Create customize performance Dashboard
You can easily create a new dashboard (Dashboards > Add New Dashboard), and add dashlets to it by clicking on the dashify icon in the upper left corner of the graph. Name the dashboard after the hostgroup, and add the graphs from each hostgroup member.
Note: This may not work well if you have way too many members. In this case, you will have to split the dashboard to a several new dashboards, based on certain criteria.
Examples: You could have separate dashboards for CPU, Memory, Disk Usage, etc.
Read more about using dashboards in Nagios XI here: https://assets.nagios.com/downloads/nag ... ios-XI.pdf
