We are trying to install the LINUX NRPE agent on a RHEL 7.3 server we want to monitor from our Nagios server.
It fails in the 4-firewall script. Below is the contents of the install.log.
Please let me know if you need anything else.
thanks,
Penny Karr | IT Infrastructure Monitoring
Harvard Vanguard Medical Associates, an Affiliate of Atrius Health
254 Second Avenue | Needham, MA 02494
P (781) 292-1853 | F (781 292-1980 | http://www.harvardvanguard.org
Email: [email protected]
[root@lvkenoemp01 linux-nrpe-agent]# ./fullinstall
Nagios Linux Agent Installer
This script will install the Nagios Linux Agent by executing all necessary
sub-scripts.
IMPORTANT: This script should only be used on a clean installed system:
RedHat Enterprise, CentOS, Fedora, or Oracle
OpenSUSE or SUSE Enterprise
Ubuntu or Debian
Do NOT use this on a system running any other distro or that
does not allow additional package installation.
Do you want to continue? [Y/n] y
Proceeding with installation...
Running './0-repos'...
Configuring Repos...
Enabling EPEL repo...
Installing EPEL PKG: ./packages/epel-release-7-2.noarch.rpm
warning: ./packages/epel-release-7-2.noarch.rpm: Header V3 RSA/SHA256 Signature, key ID 352c64e5: NOKEY
Preparing... ########################################
Updating / installing...
epel-release-7-2 ########################################
Loaded plugins: langpacks, product-id, search-disabled-repos, subscription-
: manager
This system is not registered to Red Hat Subscription Management. You can use subscription-manager to register.
epel-release.noarch 7-10 epel
perl-Net-IPv4Addr.noarch 0.10-19.el7 epel
epel-release RPM installed OK
Repos configured OK
RESULT=0
Running './1-prereqs'...
Installing prerequisites...
: manager
Package autoconf-2.69-11.el7.noarch already installed and latest version
Package gcc-4.8.5-11.el7.x86_64 already installed and latest version
Package glibc-2.17-157.el7.x86_64 already installed and latest version
Package 1:make-3.82-23.el7.x86_64 already installed and latest version
Package sudo-1.8.6p7-20.el7.x86_64 already installed and latest version
Package sysstat-10.1.5-11.el7.x86_64 already installed and latest version
Package bc-1.06.95-13.el7.x86_64 already installed and latest version
Resolving Dependencies
--> Running transaction check
---> Package libmcrypt-devel.x86_64 0:2.5.8-13.el7 will be installed
--> Processing Dependency: libmcrypt = 2.5.8-13.el7 for package: libmcrypt-devel-2.5.8-13.el7.x86_64
--> Processing Dependency: libmcrypt.so.4()(64bit) for package: libmcrypt-devel-2.5.8-13.el7.x86_64
---> Package openssl-devel.x86_64 1:1.0.1e-60.el7 will be installed
--> Processing Dependency: krb5-devel(x86-64) for package: 1:openssl-devel-1.0.1e-60.el7.x86_64
--> Processing Dependency: zlib-devel(x86-64) for package: 1:openssl-devel-1.0.1e-60.el7.x86_64
---> Package xinetd.x86_64 2:2.3.15-13.el7 will be installed
---> Package krb5-devel.x86_64 0:1.14.1-26.el7 will be installed
--> Processing Dependency: libkadm5(x86-64) = 1.14.1-26.el7 for package: krb5-devel-1.14.1-26.el7.x86_64
--> Processing Dependency: keyutils-libs-devel for package: krb5-devel-1.14.1-26.el7.x86_64
--> Processing Dependency: libcom_err-devel for package: krb5-devel-1.14.1-26.el7.x86_64
--> Processing Dependency: libselinux-devel for package: krb5-devel-1.14.1-26.el7.x86_64
--> Processing Dependency: libverto-devel for package: krb5-devel-1.14.1-26.el7.x86_64
---> Package libmcrypt.x86_64 0:2.5.8-13.el7 will be installed
---> Package zlib-devel.x86_64 0:1.2.7-17.el7 will be installed
---> Package keyutils-libs-devel.x86_64 0:1.5.8-3.el7 will be installed
---> Package libcom_err-devel.x86_64 0:1.42.9-9.el7 will be installed
---> Package libkadm5.x86_64 0:1.14.1-26.el7 will be installed
---> Package libselinux-devel.x86_64 0:2.5-6.el7 will be installed
--> Processing Dependency: libsepol-devel(x86-64) >= 2.5-6 for package: libselinux-devel-2.5-6.el7.x86_64
--> Processing Dependency: pkgconfig(libpcre) for package: libselinux-devel-2.5-6.el7.x86_64
--> Processing Dependency: pkgconfig(libsepol) for package: libselinux-devel-2.5-6.el7.x86_64
---> Package libverto-devel.x86_64 0:0.2.5-4.el7 will be installed
---> Package libsepol-devel.x86_64 0:2.5-6.el7 will be installed
---> Package pcre-devel.x86_64 0:8.32-15.el7_2.1 will be installed
Dependencies Resolved
Package Arch Version Repository Size
Installing:
libmcrypt-devel x86_64 2.5.8-13.el7 epel 13 k
openssl-devel x86_64 1:1.0.1e-60.el7 rhel7.3_Install_DVD 1.2 M
xinetd x86_64 2:2.3.15-13.el7 rhel7.3_Install_DVD 128 k
Installing for dependencies:
keyutils-libs-devel x86_64 1.5.8-3.el7 rhel7.3_Install_DVD 37 k
krb5-devel x86_64 1.14.1-26.el7 rhel7.3_Install_DVD 651 k
libcom_err-devel x86_64 1.42.9-9.el7 rhel7.3_Install_DVD 31 k
libkadm5 x86_64 1.14.1-26.el7 rhel7.3_Install_DVD 172 k
libmcrypt x86_64 2.5.8-13.el7 epel 99 k
libselinux-devel x86_64 2.5-6.el7 rhel7.3_Install_DVD 186 k
libsepol-devel x86_64 2.5-6.el7 rhel7.3_Install_DVD 74 k
libverto-devel x86_64 0.2.5-4.el7 rhel7.3_Install_DVD 12 k
pcre-devel x86_64 8.32-15.el7_2.1 rhel7.3_Install_DVD 479 k
zlib-devel x86_64 1.2.7-17.el7 rhel7.3_Install_DVD 50 k
Transaction Summary
Install 3 Packages (+10 Dependent packages)
Total download size: 3.1 M
Installed size: 6.5 M
Downloading packages:
warning: /var/cache/yum/x86_64/7Server/epel/packages/libmcrypt-2.5.8-13.el7.x86_64.rpm: Header V3 RSA/SHA256 Signature, key ID 352c64e5: NOKEY
Public key for libmcrypt-2.5.8-13.el7.x86_64.rpm is not installed
Total 7.9 MB/s | 3.1 MB 00:00
Retrieving key from file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-7
Importing GPG key 0x352C64E5:
Userid : "Fedora EPEL (7) <[email protected]>"
Fingerprint: 91e9 7d7c 4a5e 96f1 7f3e 888f 6a2f aea2 352c 64e5
Package : epel-release-7-2.noarch (installed)
Running transaction test
Transaction test succeeded
Running transaction
Warning: RPMDB altered outside of yum.
Installing : libmcrypt-2.5.8-13.el7.x86_64 1/13
Installing : libsepol-devel-2.5-6.el7.x86_64 2/13
Installing : libcom_err-devel-1.42.9-9.el7.x86_64 3/13
Installing : libkadm5-1.14.1-26.el7.x86_64 4/13
Installing : libverto-devel-0.2.5-4.el7.x86_64 5/13
Installing : keyutils-libs-devel-1.5.8-3.el7.x86_64 6/13
Installing : zlib-devel-1.2.7-17.el7.x86_64 7/13
Installing : pcre-devel-8.32-15.el7_2.1.x86_64 8/13
Installing : libselinux-devel-2.5-6.el7.x86_64 9/13
Installing : krb5-devel-1.14.1-26.el7.x86_64 10/13
Installing : 1:openssl-devel-1.0.1e-60.el7.x86_64 11/13
Installing : libmcrypt-devel-2.5.8-13.el7.x86_64 12/13
Installing : 2:xinetd-2.3.15-13.el7.x86_64 13/13
Verifying : pcre-devel-8.32-15.el7_2.1.x86_64 1/13
Verifying : zlib-devel-1.2.7-17.el7.x86_64 2/13
Verifying : keyutils-libs-devel-1.5.8-3.el7.x86_64 3/13
Verifying : 2:xinetd-2.3.15-13.el7.x86_64 4/13
Verifying : 1:openssl-devel-1.0.1e-60.el7.x86_64 5/13
Verifying : libverto-devel-0.2.5-4.el7.x86_64 6/13
Verifying : libkadm5-1.14.1-26.el7.x86_64 7/13
Verifying : libcom_err-devel-1.42.9-9.el7.x86_64 8/13
Verifying : libsepol-devel-2.5-6.el7.x86_64 9/13
Verifying : krb5-devel-1.14.1-26.el7.x86_64 10/13
Verifying : libselinux-devel-2.5-6.el7.x86_64 11/13
Verifying : libmcrypt-devel-2.5.8-13.el7.x86_64 12/13
Verifying : libmcrypt-2.5.8-13.el7.x86_64 13/13
Installed:
libmcrypt-devel.x86_64 0:2.5.8-13.el7 openssl-devel.x86_64 1:1.0.1e-60.el7
Dependency Installed:
keyutils-libs-devel.x86_64 0:1.5.8-3.el7 krb5-devel.x86_64 0:1.14.1-26.el7
libcom_err-devel.x86_64 0:1.42.9-9.el7 libkadm5.x86_64 0:1.14.1-26.el7
libmcrypt.x86_64 0:2.5.8-13.el7 libselinux-devel.x86_64 0:2.5-6.el7
libsepol-devel.x86_64 0:2.5-6.el7 libverto-devel.x86_64 0:0.2.5-4.el7
pcre-devel.x86_64 0:8.32-15.el7_2.1 zlib-devel.x86_64 0:1.2.7-17.el7
Complete!
Prerequisites installed OK
RESULT=0
Running './2-usersgroups'...
Adding users and groups...
groupadd: group 'nagios' already exists
useradd: user 'nagios' already exists
Users and groups added OK
RESULT=0
Running './3-services'...
/etc/services updated
RESULT=0
Running './4-firewall'...
The service command supports only basic LSB actions (start, stop, restart, try-restart, reload, force-reload, status). For other actions, please try to use systemctl.
FirewallD is not running
RESULT=252
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './4-firewall'
error installing LINUX NPRE agent on RHEL 7.3 server
bolson
Re: error installing LINUX NPRE agent on RHEL 7.3 server
Run:
And rerun the installation script.
systemctl start firewalld
