Good evening!
Can anybody help me? I try to use check_arping.pl script which I found here But when I try test any host from command line I give an error
The easiest way would be just to type "cpan Net::Arping" on the command line. If you need to compile it most modules come with a file in the tar called INSTALL that gives instructions.
