Audio Alerts
racinrandall
Audio Alerts
Post by racinrandall »
I have searched through the forum and did a bit of searching on Google and can't seem to figure out what is going on.
I am running Nagios 4.0.8 and I have enabled the audio alerts in the cgi.cfg file. Whenever the Nagios status page refreshes, it asks for me to authenticate again. We are using LDAP rather than local accounts (I doubt that has anything to do with it though).
I need to be able to have the audio alerts without having to re authenticate every time the page refreshes.
Any thoughts on why this is happening? When I comment out the lines for the audio settings, I no longer have to authenticate with every page refresh.
Re: Audio Alerts
Post by dwhitfield »
Please post the cgi.cfg. Are the audio files in /usr/local/nagios/share/media/ ?
racinrandall
Re: Audio Alerts
The audio files are in /usr/local/nagios/share/media/ They are user and group owned by the nagios user account and have permissions of 644.
# CGI.CFG - Sample CGI Configuration File for Nagios 4.0.8
# MAIN CONFIGURATION FILE
# This tells the CGIs where to find your main configuration file.
# The CGIs will read the main and host config files for any other
# data they might need.
main_config_file=/usr/local/nagios/etc/nagios.cfg
# PHYSICAL HTML PATH
# This is the path where the HTML files for Nagios reside.  This
# value is used to locate the logo images needed by the statusmap
# and statuswrl CGIs.
physical_html_path=/usr/local/nagios/share
# URL HTML PATH
# This is the path portion of the URL that corresponds to the
# physical location of the Nagios HTML files (as defined above).
# This value is used by the CGIs to locate the online documentation
# and graphics.  If you access the Nagios pages with an URL like
# http://www.myhost.com/nagios, this value should be '/nagios'
# (without the quotes).
url_html_path=/nagios
# CONTEXT-SENSITIVE HELP
# This option determines whether or not a context-sensitive
# help icon will be displayed for most of the CGIs.
# Values: 0 = disables context-sensitive help
#         1 = enables context-sensitive help
show_context_help=0
# PENDING STATES OPTION
# This option determines what states should be displayed in the web
# interface for hosts/services that have not yet been checked.
# Values: 0 = leave hosts/services that have not been check yet in their original state
#         1 = mark hosts/services that have not been checked yet as PENDING
use_pending_states=1
# AUTHENTICATION USAGE
# This option controls whether or not the CGIs will use any
# authentication when displaying host and service information, as
# well as committing commands to Nagios for processing.
# Read the HTML documentation to learn how the authorization works!
# NOTE: It is a really *bad* idea to disable authorization, unless
# you plan on removing the command CGI (cmd.cgi)!  Failure to do
# so will leave you wide open to kiddies messing with Nagios and
# possibly hitting you with a denial of service attack by filling up
# your drive by continuously writing to your command file!
# Setting this value to 0 will cause the CGIs to *not* use
# authentication (bad idea), while any other value will make them
# use the authentication functions (the default).
use_authentication=1
# x509 CERT AUTHENTICATION
# When enabled, this option allows you to use x509 cert (SSL)
# authentication in the CGIs.  This is an advanced option and should
# not be enabled unless you know what you're doing.
use_ssl_authentication=0
# DEFAULT USER
# Setting this variable will define a default user name that can
# access pages without authentication.  This allows people within a
# secure domain (i.e., behind a firewall) to see the current status
# without authenticating.  You may want to use this to avoid basic
# authentication if you are not using a secure server since basic
# authentication transmits passwords in the clear.
# Important:  Do not define a default username unless you are
# running a secure web server and are sure that everyone who has
# access to the CGIs has been authenticated in some manner!  If you
# define this variable, anyone who has not authenticated to the web
# server will inherit all rights you assign to this user!
#default_user_name=# removed for posting
# SYSTEM/PROCESS INFORMATION ACCESS
# This option is a comma-delimited list of all usernames that
# have access to viewing the Nagios process information as
# provided by the Extended Information CGI (extinfo.cgi).  By
# default, *no one* has access to this unless you choose to
# not use authorization.  You may use an asterisk (*) to
# authorize any user who has authenticated to the web server.
authorized_for_system_information=# removed for posting
# CONFIGURATION INFORMATION ACCESS
# can view ALL configuration information (hosts, commands, etc).
# By default, users can only view configuration information
# for the hosts and services they are contacts for. You may use
# an asterisk (*) to authorize any user who has authenticated
# to the web server.
authorized_for_configuration_information=# removed for posting
# SYSTEM/PROCESS COMMAND ACCESS
# can issue shutdown and restart commands to Nagios via the
# command CGI (cmd.cgi).  Users in this list can also change
# the program mode to active or standby. By default, *no one*
# has access to this unless you choose to not use authorization.
# You may use an asterisk (*) to authorize any user who has
# authenticated to the web server.
authorized_for_system_commands=# removed for posting
# GLOBAL HOST/SERVICE VIEW ACCESS
# These two options are comma-delimited lists of all usernames that
# can view information for all hosts and services that are being
# monitored.  By default, users can only view information
# for hosts or services that they are contacts for (unless you
# you choose to not use authorization). You may use an asterisk (*)
# to authorize any user who has authenticated to the web server.
authorized_for_all_services=*
authorized_for_all_hosts=*
# GLOBAL HOST/SERVICE COMMAND ACCESS
# can issue host or service related commands via the command
# CGI (cmd.cgi) for all hosts and services that are being monitored.
# By default, users can only issue commands for hosts or services
# that they are contacts for (unless you you choose to not use
# authorization).  You may use an asterisk (*) to authorize any
# user who has authenticated to the web server.
authorized_for_all_service_commands=# removed for posting
authorized_for_all_host_commands=# removed for posting
# READ-ONLY USERS
# A comma-delimited list of usernames that have read-only rights in
# the CGIs.  This will block any service or host commands normally shown
# on the extinfo CGI pages.  It will also block comments from being shown
# to read-only users.
authorized_for_read_only=
# STATUSMAP BACKGROUND IMAGE
# This option allows you to specify an image to be used as a
# background in the statusmap CGI.  It is assumed that the image
# resides in the HTML images path (i.e. /usr/local/nagios/share/images).
# This path is automatically determined by appending "/images"
# to the path specified by the 'physical_html_path' directive.
# Note:  The image file may be in GIF, PNG, JPEG, or GD2 format.
# However, I recommend that you convert your image to GD2 format
# (uncompressed), as this will cause less CPU load when the CGI
# generates the image.
#statusmap_background_image=smbackground.gd2
# STATUSMAP TRANSPARENCY INDEX COLOR
# These options set the r,g,b values of the background color used the statusmap CGI,
# so normal browsers that can't show real png transparency set the desired color as
# a background color instead (to make it look pretty).
# Defaults to white: (R,G,B) = (255,255,255).
#color_transparency_index_r=255
#color_transparency_index_g=255
#color_transparency_index_b=255
# DEFAULT STATUSMAP LAYOUT METHOD
# This option allows you to specify the default layout method
# the statusmap CGI should use for drawing hosts.  If you do
# not use this option, the default is to use user-defined
# coordinates.  Valid options are as follows:
#       0 = User-defined coordinates
#       1 = Depth layers
#       2 = Collapsed tree
#       3 = Balanced tree
#       4 = Circular
#       5 = Circular (Marked Up)
default_statusmap_layout=5
# DEFAULT STATUSWRL LAYOUT METHOD
# the statuswrl (VRML) CGI should use for drawing hosts.  If you
# do not use this option, the default is to use user-defined
#       3 = Balanced tree
#       4 = Circular
default_statuswrl_layout=4
# STATUSWRL INCLUDE
# This option allows you to include your own objects in the
# generated VRML world.  It is assumed that the file
# resides in the HTML path (i.e. /usr/local/nagios/share).
#statuswrl_include=myworld.wrl
# PING SYNTAX
# This option determines what syntax should be used when
# attempting to ping a host from the WAP interface (using
# the statuswml CGI.  You must include the full path to
# the ping binary, along with all required options.  The
# $HOSTADDRESS$ macro is substituted with the address of
# the host before the command is executed.
# Please note that the syntax for the ping binary is
# notorious for being different on virtually ever *NIX
# OS and distribution, so you may have to tweak this to
# work on your system.
ping_syntax=/bin/ping -n -U -c 5 $HOSTADDRESS$
# REFRESH RATE
# This option allows you to specify the refresh rate in seconds
# of various CGIs (status, statusmap, extinfo, and outages).
refresh_rate=600
# DEFAULT PAGE LIMIT
# This option allows you to specify the default number of results
# displayed on the status.cgi.  This number can be adjusted from
# within the UI after the initial page load. Setting this to 0
# will show all results.
result_limit=100
# ESCAPE HTML TAGS
# This option determines whether HTML tags in host and service
# status output is escaped in the web interface.  If enabled,
# your plugin output will not be able to contain clickable links.
escape_html_tags=1
# SOUND OPTIONS
# These options allow you to specify an optional audio file
# that should be played in your browser window when there are
# problems on the network.  The audio files are used only in
# the status CGI.  Only the sound for the most critical problem
# will be played.  Order of importance (higher to lower) is as
# follows: unreachable hosts, down hosts, critical services,
# warning services, and unknown services. If there are no
# visible problems, the sound file optionally specified by
# 'normal_sound' variable will be played.
# <varname>=<sound_file>
# Note: All audio files must be placed in the /media subdirectory
# under the HTML path (i.e. /usr/local/nagios/share/media/).
host_unreachable_sound=hostdown.wav
host_down_sound=hostdown.wav
service_critical_sound=critical.wav
service_warning_sound=warning.wav
service_unknown_sound=warning.wav
normal_sound=noproblem.wav
# URL TARGET FRAMES
# These options determine the target frames in which notes and
# action URLs will open.
action_url_target=_self
notes_url_target=_self
# LOCK AUTHOR NAMES OPTION
# This option determines whether users can change the author name
# when submitting comments, scheduling downtime.  If disabled, the
# author names will be locked into their contact name, as defined in Nagios.
# Values: 0 = allow editing author names
#         1 = lock author names (disallow editing)
lock_author_names=1
# SPLUNK INTEGRATION OPTIONS
# These options allow you to enable integration with Splunk
# in the web interface.  If enabled, you'll be presented with
# "Splunk It" links in various places in the CGIs (log file,
# alert history, host/service detail, etc).  Useful if you're
# trying to research why a particular problem occurred.
# For more information on Splunk, visit http://www.splunk.com/
# This option determines whether the Splunk integration is enabled
# Values: 0 = disable Splunk integration
#         1 = enable Splunk integration
#enable_splunk_integration=1
# This option should be the URL used to access your instance of Splunk
#splunk_url=http://127.0.0.1:8000/
# NAVIGATION BAR SEARCH OPTIONS
# The following options allow to configure the navbar search. Default
# is to search for hostnames. With enabled navbar_search_for_addresses,
# the navbar search queries IP addresses as well. It's also possible
# to enable search for aliases by setting navbar_search_for_aliases=1.
navbar_search_for_addresses=1
Re: Audio Alerts
It could be a security setting in your web browser that when it receives the audio file, it needs to authenticate to play the file. Do you think that could be it?
Can you set your browser to save the password so you do not have to re-type it in?
Another thing to try is if you are using Firefox this Add-In can play audio files when an alert happens.
https://addons.mozilla.org/en-US/firefo ... src=search
You could use that instead and see if it works.
racinrandall
Re: Audio Alerts
We e in an environment that is fairly locked down and we are unable to modify many settings on the workstations and only have control on the server.
When I comment out the lines for the audio alerts I don't have to re-authenticate. This is only happening in IE. Firefox does not require me to re-authenticate, but also does not play the audio file.
I have attempted the Firefox plugin as well but have been unsuccessful with it as well.
Re: Audio Alerts
Is there a reason you can just get email alerts and have your email make a sound? Here are instructions for customizing Thunderbird: https://support.mozilla.org/en-US/kb/ho ... mail-sound
Other email clients have similar options.
racinrandall
Re: Audio Alerts
The alerts are needed for a watch station in our command center. There are many screens and systems the watch is monitoring. We are looking for something to call their attention to the Nagios screen. I'm not sure that an email alert with email playing a sound is how they want this setup.
We already send out the email alerts, however we need to "wake up" the watch stander when a new alert pops up.
Re: Audio Alerts
Did you try the Firefox add-on? Also, I have to ask...does sound work at all on your machine? Does Firefox display any error?
racinrandall
Re: Audio Alerts
Sound does work on my PC. When I enable the sound I have to re-authenticate to the web interface every time it refreshes.
Our Windows PCs do not have Firefox and my Solaris system I was unable to get the plugin working (I believe due to network security settings).
Re: Audio Alerts
Can you try Portable Firefox on your windows PC? https://portableapps.com/apps/internet/firefox_portable
Firefox on Solaris may not have the necessary media plugins. Are you able to play mp3s, etc on the Firefox in Solaris? For example, does https://ia600602.us.archive.org/31/item ... 744/01.mp3 play?
Unfortunately, if you are unable to modify your security settings, there may be nothing we can do.
