Unable to export report
chillipepper
Post by chillipepper »
While trying to export report for queries the PDF exported contains no reports and has "error" marked on it.
Re: Unable to export report
Can you login to the NNA server as root and run the following command.
tail -f /var/log/httpd/*_log
Then login to the NNA GUI and try and export the report as a PDF file, and if you see any errors in the screen running the tail command, post them here so we can view them.
