Mrtg issue
gtsoukatou
Mrtg issue
Post by gtsoukatou »
I have installed mrtg on Nagios Core, but i get the message: MRTG data has expired (x minutes old). What can be done for this?
I also can not fix Nagios::Config... ***FAIL*** in the following.
[root@nagioscore nagiosgraph-1.5.2]# ./install.pl --check-prereq
checking required PERL modules
Carp...1.11
CGI...3.51
Data::Dumper...2.124
Digest::MD5...2.39
File::Basename...2.77
File::Find...1.14
MIME::Base64...3.08
POSIX...1.17
RRDs...1.3008
Time::HiRes...1.9721
checking optional PERL modules
GD...2.44
checking nagios installation
found nagios exectuable at /usr/local/nagios/bin/nagios
found nagios init script at /etc/init.d/nagios
checking web server installation
found apache executable at /usr/sbin/httpd
found apache init script at /etc/init.d/httpd
Re: Mrtg issue
The MRTG data has expired message could be caused by the crontab entry is missing or not running.
Take a look at this link for installing MRTG on your system and verify that cron is setup and running for MRTG.
http://oss.oetiker.ch/mrtg/doc/mrtg-unix-guide.en.html
The other issue for installing Nagiosgraph, you may want to search their forums for that error.
https://sourceforge.net/p/nagiosgraph/discussion/394748
