Error incheck_http when checking cert expiration
ajacobs
Post by ajacobs »
Hi
I am in the process of upgrading our nagios servers from debian7 to debian9, and have run into a problem with check_http.
In the old version (2.1.4) the command "check_http -H hostname -S -C 20 --sni" gives a correct answer, but the new version (2.2.1) gives a wrong answer because the server responds with a 403 HTTP response. That is it always returns 1 no matter the expiry of the cert.
Is this a known problem, and is there a workaround ?
Best regards
Allan
kyang
Re: Error incheck_http when checking cert expiration
Post by kyang »
Hi @ajacobs,
This sounds like a known issue that has been reported and added to the bug fixes for the next version.
https://github.com/nagios-plugins/nagio ... issues/280
https://github.com/nagios-plugins/nagio ... issues/299
There is the option of downgrading back to 2.1.4 if you need the -C certificate check.
Does this help?
Post by dwhitfield »
Thanks @kyang!
OP, let us know if you have any additional questions.
