Nagios Server Disk Management
ecarrasq
Post by ecarrasq »
System Info
Linux Distribution and version?
*Linux version 2.6.18-274.3.1.el5 ([email protected]) (gcc version 4.1.2 20080704 (Red Hat 4.1.2-51)) #1 SMP Tue Sep 6 20:14:03 EDT 2011
CentOS release 5.7 (Final)
32 or 64bit?
32 bit
VMware Image or Manual Install of XI?
VMware Image
Are there specials configurations on your system, ie; is Gnome installed? Are you using a proxy? Are you using SSL?
No.
ISSUE:
What is best practice in maintaining Nagios Server disk space usage to a minimum? Any files that can be deleted, or moved out of the server?
Eddie
agriffin
Re: Nagios Server Disk Management
Post by agriffin »
Log files are generally safe to delete if you don't need the information. You could also offload MySQL to another server
jtata
Post by jtata »
I added a new virtual disk mounted under /store as backups can get a bit large over time as well.
