Customizing graphs per user
nms
Post by nms »
On the system settings, we have set to see the High charts as a "line". For the purpose of launching some graphs on a big screen we thought of the possibility to show the graphs in "area". However if we change this setting, this will affect all graphs. So thoughts were if it was possible to have this setting for a particular user in which the graphs are shown as an area.
Is this possible or this is a global setting?
Rgds,
Matthew
Re: Customizing graphs per user
Yes, you can set just that one user to use a different "line" for the graphs. What they would need to do is to login to the GUI and click on their username in the top right corner.
Then in that menu, you can change the "Default Type for Highcharts Graphs" for just that one user.
nms
Post by nms »
Hi tgriep,
Thanks for the answer. This thread can be locked.
Rgds,
Matthew
