NCPA Configuration Wizard - Howto Modify Default Metrics.
TBT
Post by TBT »
We're looking to modify default metrics within the NCPA Configuration Wizard. For example, CPU warning and alarm thresholds. I've viewed Host Template Management for NCPA, however, these values differ from what is shown within the Wizard.
Please advise.
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
Re: NCPA Configuration Wizard - Howto Modify Default Metrics
The wizard (to my knowledge) does not use the host template values when populating the defaults in its configuration phase. You would need to modify the wizard, located under /usr/local/nagiosxi/html/includes/configwizards/ncpa. There are some references in ncpa.inc.php like:
            // Set defaults for services
            $default_services['cpu_usage']['monitor'] = 'on';
            $default_services['cpu_usage']['warning'] = 20;
            $default_services['cpu_usage']['critical'] = 40;
            $default_services['cpu_usage']['average'] = 1;
            $default_services['memory_usage']['monitor'] = 'on';
            $default_services['memory_usage']['warning'] = 50;
            $default_services['memory_usage']['critical'] = 80;
            $default_services['swap_usage']['monitor'] = 'on';
            $default_services['swap_usage']['warning'] = 50;
            $default_services['swap_usage']['critical'] = 80;
TBT
Post by TBT »
tmcdonald wrote:The wizard (to my knowledge) does not use the host template values when populating the defaults in its configuration phase. You would need to modify the wizard, located under /usr/local/nagiosxi/html/includes/configwizards/ncpa. There are some references in ncpa.inc.php like:
When the module updates these config changes wouldn't carry over. Perhaps Nagios will consider a templating in the next release?
We have templating currently, but it only affects steps 3-5 (the pages that are common to all wizards). It is my understanding that wizards are being overhauled in XI 6, but I do not at this time have specifics on what will be configurable.
