Nagios Core
ivp2015
Nagios Core
Post by ivp2015 »
not able to get get email notification from nagios core and contact is already added in contact.cfg,
also setup postfix and send mail use both
Use plugin
check-host-alive $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
check_dhcp $USER1$/check_dhcp $ARG1$
check_ftp $USER1$/check_ftp -H $HOSTADDRESS$ $ARG1$
check_hpjd $USER1$/check_hpjd -H $HOSTADDRESS$ $ARG1$
check_http $USER1$/check_http -I $HOSTADDRESS$ $ARG1$
check_imap $USER1$/check_imap -H $HOSTADDRESS$ $ARG1$
check_local_disk $USER1$/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
check_local_load $USER1$/check_load -w $ARG1$ -c $ARG2$
check_local_mrtgtraf $USER1$/check_mrtgtraf -F $ARG1$ -a $ARG2$ -w $ARG3$ -c $ARG4$ -e $ARG5$
check_local_procs $USER1$/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
check_local_swap $USER1$/check_swap -w $ARG1$ -c $ARG2$
check_local_users $USER1$/check_users -w $ARG1$ -c $ARG2$
check_nt $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -s valley@@123 -v $ARG1$ $ARG2$
check_ping $USER1$/check_ping -H $HOSTADDRESS$ -w $ARG1$ -c $ARG2$ -p 5
check_pop $USER1$/check_pop -H $HOSTADDRESS$ $ARG1$
check_smtp $USER1$/check_smtp -H $HOSTADDRESS$ $ARG1$
check_snmp $USER1$/check_snmp -H $HOSTADDRESS$ $ARG1$
check_ssh $USER1$/check_ssh $ARG1$ $HOSTADDRESS$
check_tcp $USER1$/check_tcp -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
check_udp $USER1$/check_udp -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
notify-host-by-email /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
notify-service-by-email /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
process-host-perfdata /usr/bin/printf "%b" "$LASTHOSTCHECK$\t$HOSTNAME$\t$HOSTSTATE$\t$HOSTATTEMPT$\t$HOSTSTATETYPE$\t$HOSTEXECUTIONTIME$\t$HOSTOUTPUT$\t$HOSTPERFDATA$\n" >> /usr/local/nagios/var/host-perfdata.out
process-service-perfdata /usr/bin/printf "%b" "$LASTSERVICECHECK$\t$HOSTNAME$\t$SERVICEDESC$\t$SERVICESTATE$\t$SERVICEATTEMPT$\t$SERVICESTATETYPE$\t$SERVICEEXECUTIONTIME$\t$SERVICELATENCY$\t$SERVICEOUTPUT$\t$SERVICEPERFDATA$\n" >> /usr/local/nagios/var/service-perfdata.out
use https://www.unixmen.com/send-alerts-nag ... ail-yahoo/
https://support.nagios.com/forum/viewto ... =7&t=40122
tacolover101
Re: Nagios Core
Post by tacolover101 »
i would try the suggestion outlined here - https://www.freelock.com/kb/postfix-relayhost
if that doesn't work, troubleshoot your way through the notification.
1. get it working over the command line, without Nagios
2. then set it up in Nagios once you confirm it's working
it could be a variety of different things ranging from your SMTP settings / where mail is installed - without any direct info it's hard to say.
vnoc
Re: Nagios Core
Post by vnoc »
did you configure the mail server .
you will be finding it in below path check this once
vi /etc/mail.rc
at the bottom you have to configure the mail server ip port as below
set smtp=smtp://Mail Server IP
set from=" mail id" --from which you want to receive
set smtp-auth=login
set smtp-auth-username=username --- smtp mail username
set smtp-auth-password=password --- smtp mail password
cdienger
Re: Nagios Core
Post by cdienger »
Did the above suggestions help?
To tacolover101's point, try to determine where the problem is by trying to send an email from the command line. For example:
/usr/bin/printf "test" | /bin/mail -s "test2" EXTERNALEMAIL@ADDRESS
/usr/bin/printf "test" | /bin/mail -s "test2" root@localhost
ivp2015
Re: Nagios Core
Post by ivp2015 »
Hey its working here problem with my postfix
bolson
Re: Nagios Core
Post by bolson »
May we close this topic?
ivp2015
Re: Nagios Core
Post by ivp2015 »
Yes, now my issue has been resolve Thanks a lot for your aggressive support.
bolson
Re: Nagios Core
Post by bolson »
Closing topic as resolved.
Thank you for using the Nagios Support Forum.
