Nagios XI API notes
whateverman
Nagios XI API notes
Post by whateverman »
In my nagios check i usually implement a note with a link to the relevant documentation for said host/service/whatever.
How do i set this note via the API? Is it even supported?
Re: Nagios XI API notes
In my nagios check i usually implement a note...
Can you elaborate on this? How exactly are you doing this? Are you adding a value to the "notes" directive?
Example:
notes	note_string
