How to secure password in the newest NSClient 0.5.0.62.
In the old versions command nsclient.exe -encrypt works but not now
I want to get following settings:
[Settings]
;# OBFUSCATED PASSWORD
; This is the same as the password option but here you can store the password in an obfuscated manner.
; *NOTICE* obfuscation is *NOT* the same as encryption, someone with access to this file can still figure out the
; password. Its just a bit harder to do it at first glance.
obfuscated_password=Jw0KAUUdXlAAUwASDAAB
nsclient secure passowrd
Re: nsclient secure passowrd
This is a NSClient-specific question, you'll want to ask on their forums: https://forums.nsclient.org/t/nsclient- ... sword/4636
It looks like this functionality has been removed with recent versions (like 0.5.x):
https://github.com/mickem/nscp/blob/mas ... gelog#L581
2015-10-27 Michael Medin
* Removed encrypt from the API has it has not been implemented for some time
@mcapra thanks a lot. Topic should be closed.
bolson
Closing topic as resolved.
Thank you for using the Nagios Support Forum.
