I've had some problems with rawOut gadget in NagVis, is there any special reason why this (shown on picture below), would happen? I have noticed it is not only rawOut but all other gadgets as well, i have tried restarting it, Deleting it, Copying it back.. All failed, I don't know what to do next so if you can hep me i would appreciate it!
Thank you in advance!
Edit: Note that this happens in both Edit and Normal mode
NagVis - Gadget Error's And Other Errors
Re: NagVis - Gadget Error's
Just to clarify, you're trying to troubleshoot the broken image, correct?
What is the output of:
There should be at least 27 files in there with ownership set to apache:apache and rights set to 664:
Files attached and you can run:
if needed.
ll /usr/local/nagvis/share/frontend/nagvis-js/images/internal
chown apache:apache /usr/local/nagvis/share/frontend/nagvis-js/images/internal/*
chmod 755 /usr/local/nagvis/share/frontend/nagvis-js/images/internal/*
Hey there, thank's for your reply and i would like to mention that what you have sent me hasn't fixed my issue since the icon's are working but the gadgets aren't, this issue has appeared a few days ago..
As you could've seen on the left the icon, that icon is normal.. I'm using rawOut gadget that can be found here:
https://exchange.nagvis.org/exchange/Gadgets/rawOut/
If you look at the picture down below on the webpage shown above, you can see what i'm trying to do here..
It has worked before but it has stopped working for unknown reason..
Note: "All of my gadgets aren't working so i believe it is NagVis problem, would it be possible?"
Is there anyway i could reinstall NagVis gadgets / plugins, or even reinstall whole NagVis?
Or even better, could i do the same thing as this gadget with any other option already available in normal NagVis without any additional modifications?
I have also noticed another problem that i do not know what is causing it...
Notice: Undefined index: active in /usr/local/nagiosxi/html/includes/components/ccm/page_templates/form_header.php on line 78
Warning: explode() expects parameter 2 to be string, array given in /usr/local/nagiosxi/html/includes/utils-macros.inc.php on line 33 Warning: Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/utils-macros.inc.php on line 34
These 3 errors prevent me to create any hosts or servicesNotice: Undefined index: hosts_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 166 Notice: Undefined index: hosts_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 169 Notice: Undefined index: hosts_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 172 Notice: Undefined index: hostgroups_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 166 Notice: Undefined index: hostgroups_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 169 Notice: Undefined index: hostgroups_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 172 Notice: Undefined index: servicegroups_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 166 Notice: Undefined index: servicegroups_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 169 Notice: Undefined index: servicegroups_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 172 Notice: Undefined index: contactgroups_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 166 Notice: Undefined index: contactgroups_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 169 Notice: Undefined index: contactgroups_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 172 Notice: Undefined index: contacts_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 166 Notice: Undefined index: contacts_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 169 Notice: Undefined index: contacts_tploptions in /usr/local/nagiosxi/html/includes/components/ccm/includes/hidden_overlay_functions.inc.php on line 172
Re: NagVis - Gadget Error's And Other Errors
Please create another forum topic for your other support issue.
For the Nagvis issue, please send us a copy of the map in questions from /usr/local/nagvis/etc/maps so that we can see how it's setup.
Thank you
Thank you
There you go all maps inside
The only map file in the archive you sent doesn't contain any gadgets, can you send the map from the screenshot so that I can see how you have it configured?
Thank you
Thank you
It seems problem fixed it self for now.. Tough i don't know what it was, i hope it will work for nowssax wrote:The only map file in the archive you sent doesn't contain any gadgets, can you send the map from the screenshot so that I can see how you have it configured?
Thank you
