disable/enable notifications via rest api
jh129666
Post by jh129666 »
I found the below commands to disable/enable notifications via the rest API.
What are the rest API commands to disable/enable notifications for all services in a hostgroup, including the hosts?
curl -XPOST "http://192.168.x.x/nagiosxi/api/v1/conf ... u&pretty=1" -d "host_name=localhost&address=127.0.0.1&max_check_attempts=2&check_period=24x7&contacts=nagiosadmin&notification_interval=5&notification_period=24x7&notifications_enabled=0&applyconfig=1"
curl -XPOST "http://192.168.x.x/nagiosxi/api/v1/conf ... u&pretty=1" -d "host_name=localhost&address=127.0.0.1&max_check_attempts=2&check_period=24x7&contacts=nagiosadmin&notification_interval=5&notification_period=24x7&notifications_enabled=1&applyconfig=1"
Jeff
Re: disable/enable notifications via rest api
At present there isn't a single command that would do them all in bulk. You would need to process the command for each separately.
matson-itops
Post by matson-itops »
any hope of getting api to disable / enable service checks?
kyang
Post by kyang »
Hi matson-itops,
I think we were working on another thread about this question?
May we continue on that one so us techs don't answer a question twice?
Thanks for understanding!
Otherwise, there will be more API-end points coming in XI 5.5
https://www.nagios.com/roadmaps/
