Problem logging in after Upgrade
I upgraded to the latest version of fusion, and failed to record the nagiosadmin password. I followed the procedure /usr/local/nagiosfusion/scripts/reset_nagiosadmin_password.sh --password=<new password> but I continue to get the error "Username/password do not match data stored in Nagios Fusion database." Comments, suggestions are welcome.
bolson
Re: Problem logging in after Upgrade
Run the command in this way:
/usr/local/nagiosfusion/scripts/reset_nagiosadmin_password.sh <new password>Re: Problem logging in after Upgrade
Well Brian, you knocked that one out of the park.
Thanks, that resolved the problem.
bolson
Glad to help
Closing topic as resolved.
Thank you for using the Nagios Support Forum.
