Fusion 4 Database Size
daniel.mazik
I've noticed that our new Fusion 4 server is chewing through HDD space recently. While looking at the fusion MySQL DB I noticed the polled_extras table is using 30+ GB of disk space. Is there a way to clean this table and/or limit it's size?
Re: Fusion 4 Database Size
There is a cron job that runs every 5 minutes which should be clearing the table of old entries.
Maybe there is a corrupt table causing the issue.
If your server is running on Centos / RHEL 6, run the following and post the output.
If it is running on Centos / RHEL 7, run the following and post the output.
Run these commands as root and post the output.
tail -100 /var/log/mysqld.logCode: Select all
tail -100 /var/log/mariadb/mariadb.logCode: Select all
tail -50 /usr/local/nagiosfusion/var/log/dbmaint_subsys.log
echo 'SELECT TABLE_NAME, ENGINE FROM information_schema.TABLES where TABLE_SCHEMA = "fusion";' | mysql -t -u fusion -pfusionBe sure to check out our Knowledgebase for helpful articles and solutions!
daniel.mazik
I am running the Nagios VMWare appliance (OVA) on centos-release-6-9.el6.12.3.x86_64. Below is the output from the mysql.log. NOTE the root partition was completely out of disk space this morning which caused the errors seen. After I grew the partition they stopped (see entries at 170807 10:10:00):
I checked dbmaint_subsys.log and it was empty.
Below is the output from the mysql select statement:
InnoDB: Reading tablespace information from the .ibd files...
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer...
170807 9:23:12 InnoDB: Started; log sequence170807 09:23:12 mysqld_safe Number of processes running now: 0
170807 09:23:12 mysqld_safe mysqld restarted
170807 9:23:12 InnoDB: Initializing buffer pool, size = 8.0M
170807 9:23:12 InnoDB: Completed initialization of buffer pool
InnoDB: The log sequence number in ibdata files does not match
InnoDB: the log sequence number in the ib_logfiles!
170807 9:23:12 InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: buffer...
170807 9:23:12 InnoDB: Started; log sequence number 7 1175073293
170807 9:23:12 [ERROR] /usr/libexec/mysqld: Error writing file '/var/run/mysqld/mysqld.pid' (Errcode: 28)
170807 9:23:12 [ERROR] Can't start server: can't create PID file: No space left on device
InnoDB: buffer...
InnoDB: buffer...
InnoDB: buffer...
170807 9:23:13 InnoDB: Initializing buffer pool, size = 8.0M
170807 9:23:13 InnoDB: Completed initialization of buffer pool
170807 9:23:13 InnoDB: Database was not shut down normally!
InnoDB: buffer...
170807 9:23:13 InnoDB: Started; log sequence170807 09:23:13 mysqld_safe Number of processes running now: 0
170807 09:23:13 mysqld_safe mysqld restarted
InnoDB: buffer...
170807 9:23:13 InnoDB: Started; log sequence number 7 1175073293
170807 9:23:13 [Note] Event Scheduler: Loaded 0 events
170807 9:23:13 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.1.73' socket: '/var/lib/mysql/mysql.sock' port: 3306 Source distribution
170807 10:09:34 [Note] /usr/libexec/mysqld: Normal shutdown
170807 10:09:34 [Note] Event Scheduler: Purging the queue. 0 events
170807 10:09:34 InnoDB: Starting shutdown...
170807 10:09:36 InnoDB: Shutdown completed; log sequence number 7 1176057449
170807 10:09:36 [Note] /usr/libexec/mysqld: Shutdown complete
170807 10:09:36 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
170807 10:10:00 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
170807 10:10:00 InnoDB: Initializing buffer pool, size = 8.0M
170807 10:10:00 InnoDB: Completed initialization of buffer pool
170807 10:10:00 InnoDB: Started; log sequence number 7 1176057449
170807 10:10:00 [Note] Event Scheduler: Loaded 0 events
170807 10:10:00 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.1.73' socket: '/var/lib/mysql/mysql.sock' port: 3306 Source distributionBelow is the output from the mysql select statement:
| TABLE_NAME | ENGINE |
| commands | InnoDB |
| dashboards | InnoDB |
| dashlets | InnoDB |
| dashlets_params | InnoDB |
| log | InnoDB |
| meta | InnoDB |
| options | InnoDB |
| polled_averages | InnoDB |
| polled_data | InnoDB |
| polled_deltas | InnoDB |
| polled_extras | InnoDB |
| polling_lock | InnoDB |
| servers | InnoDB |
| sysstat | InnoDB |
| users | InnoDB |
| users_servers | InnoDB |
| views | InnoDB |
+-----------------+--------+Re: Fusion 4 Database Size
I have more commands for you. Can you run these and post the output?
echo 'show table status;' |mysql -u fusion -pfusion fusion -t
/usr/bin/php /usr/local/nagiosfusion/cron/dbmaint_subsys.php
ls -l /var/lib/mysql
ls -l /var/lib/mysql/fusion
df -h
df -iBe sure to check out our Knowledgebase for helpful articles and solutions!
daniel.mazik
echo 'show table status;' |mysql -u fusion -pfusion fusion -t:
/usr/bin/php /usr/local/nagiosfusion/cron/dbmaint_subsys.php: No output
ls -l /var/lib/mysql:
ls -l /var/lib/mysql/fusion:
df -h (I grew the default root partition on the Nagios appliance to 50G):
df -i:
| Name | Engine | Version | Row_format | Rows | Avg_row_length | Data_length | Max_data_length | Index_length | Data_free | Auto_increment | Create_time | Update_time | Check_time | Collation | Checksum | Create_options | Comment |
| commands | InnoDB | 10 | Compact | 0 | 0 | 16384 | 0 | 0 | 4194304 | 1 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| dashboards | InnoDB | 10 | Compact | 21 | 780 | 16384 | 0 | 0 | 4194304 | 22 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| dashlets | InnoDB | 10 | Compact | 95 | 172 | 16384 | 0 | 0 | 4194304 | 105 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| dashlets_params | InnoDB | 10 | Compact | 180 | 91 | 16384 | 0 | 0 | 4194304 | NULL | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| log | InnoDB | 10 | Compact | 13 | 1260 | 16384 | 0 | 0 | 4194304 | 14 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| meta | InnoDB | 10 | Compact | 57 | 287 | 16384 | 0 | 0 | 4194304 | 60 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| options | InnoDB | 10 | Compact | 48 | 341 | 16384 | 0 | 0 | 4194304 | 49 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| polled_averages | InnoDB | 10 | Compact | 14 | 1170 | 16384 | 0 | 16384 | 4194304 | 60937 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| polled_data | InnoDB | 10 | Compact | 30564 | 257 | 7880704 | 0 | 0 | 4194304 | 30469 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| polled_deltas | InnoDB | 10 | Compact | 14 | 1170 | 16384 | 0 | 16384 | 4194304 | 60923 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| polled_extras | InnoDB | 10 | Compact | 249133 | 141839 | 35337011200 | 0 | 21577728 | 4194304 | 302722 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| polling_lock | InnoDB | 10 | Compact | 4 | 4096 | 16384 | 0 | 0 | 4194304 | 30471 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| servers | InnoDB | 10 | Compact | 4 | 4096 | 16384 | 0 | 16384 | 4194304 | 5 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| sysstat | InnoDB | 10 | Compact | 9 | 1820 | 16384 | 0 | 16384 | 4194304 | 172299 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| users | InnoDB | 10 | Compact | 12 | 1365 | 16384 | 0 | 16384 | 4194304 | 13 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| users_servers | InnoDB | 10 | Compact | 6 | 2730 | 16384 | 0 | 0 | 4194304 | NULL | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
| views | InnoDB | 10 | Compact | 48 | 341 | 16384 | 0 | 0 | 4194304 | 49 | 2017-07-26 16:30:09 | NULL | NULL | utf8_general_ci | NULL | | |
total 35043888
drwx------ 2 mysql mysql 4096 Jul 26 16:30 fusion
-rw-rw---- 1 mysql mysql 35874430976 Aug 8 09:35 ibdata1
-rw-rw---- 1 mysql mysql 5242880 Aug 8 09:35 ib_logfile0
-rw-rw---- 1 mysql mysql 5242880 Aug 8 09:35 ib_logfile1
drwx------ 2 mysql mysql 4096 Jul 26 16:30 mysql
srwxrwxrwx 1 mysql mysql 0 Aug 7 10:10 mysql.sock
drwx------ 2 mysql mysql 4096 Jul 26 16:30 test
total 208
-rw-rw---- 1 mysql mysql 9008 Jul 26 16:30 commands.frm
-rw-rw---- 1 mysql mysql 8918 Jul 26 16:30 dashboards.frm
-rw-rw---- 1 mysql mysql 9102 Jul 26 16:30 dashlets.frm
-rw-rw---- 1 mysql mysql 8632 Jul 26 16:30 dashlets_params.frm
-rw-rw---- 1 mysql mysql 65 Jul 26 16:30 db.opt
-rw-rw---- 1 mysql mysql 8816 Jul 26 16:30 log.frm
-rw-rw---- 1 mysql mysql 8756 Jul 26 16:30 meta.frm
-rw-rw---- 1 mysql mysql 8632 Jul 26 16:30 options.frm
-rw-rw---- 1 mysql mysql 8782 Jul 26 16:30 polled_averages.frm
-rw-rw---- 1 mysql mysql 11752 Jul 26 16:30 polled_data.frm
-rw-rw---- 1 mysql mysql 8774 Jul 26 16:30 polled_deltas.frm
-rw-rw---- 1 mysql mysql 8714 Jul 26 16:30 polled_extras.frm
-rw-rw---- 1 mysql mysql 8712 Jul 26 16:30 polling_lock.frm
-rw-rw---- 1 mysql mysql 9304 Jul 26 16:30 servers.frm
-rw-rw---- 1 mysql mysql 8722 Jul 26 16:30 sysstat.frm
-rw-rw---- 1 mysql mysql 9296 Jul 26 16:30 users.frm
-rw-rw---- 1 mysql mysql 8748 Jul 26 16:30 users_servers.frm
-rw-rw---- 1 mysql mysql 8724 Jul 26 16:30 views.frm
/dev/mapper/VolGroup-lv_root
47G 35G 9.4G 79% /
tmpfs 498M 0 498M 0% /dev/shm
/dev/sda1 477M 95M 357M 22% /boot
Filesystem Inodes IUsed IFree IUse% Mounted on
3090672 46155 3044517 2% /
tmpfs 127378 1 127377 1% /dev/shm
/dev/sda1 128016 56 127960 1% /boot
daniel.mazik
Also, after running the last set of commands suggested I am not able to see any data in Fusion for any of my fused servers. See screenshot attached.
I brought this issue up with the developer and he it going to look at why the table is growing and it not getting truncated.
In the mean time, you can manually truncate the tables by running the following in a root shell on the server.
Keep an eye on the size of the table and if it grows too large again, run the truncate script again.
cd /usr/local/nagiosfusion/scripts
./truncate_polled.phpBe sure to check out our Knowledgebase for helpful articles and solutions!
bheden
- Product Development Manager
How many servers do you have fused?
How many hosts/services for each server?
Was everything displaying properly at one point?
I *just* realized I did not leave the polling retention data option in the system settings!
Nagios Enterprises
Senior Developer
Nagios Enterprises
Senior Developer
daniel.mazik
We have 4 fused XI appliances with a total of 370 hosts and 7500 services. I was wondering where the polling retention settings were
. Also, after running the truncate_polled.php script I started getting data from our fused servers again.
That is good news that it is working for you.
Keep an eye on that table and if it gets that large again, let us know.
