Nagios Core 4.1.2 and check_vmware_api.pl
emi65
Post by emi65 »
I downloaded from
https://exchange.nagios.org/directory/P ... 1502114147
the last version of check_vmare_api.pl
When I run it with -h option I got this error
Can't locate Monitoring/Plugin/Functions.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ./check_vmware_api.pl.ORIG line 39.
BEGIN failed--compilation aborted at ./check_vmware_api.pl line 39.
In the /usr/share/perl5/vendor_perl folder I have
Nagios and NOT Monitoring folder
In Nagios folder I have Plugin/Functions.pm file
How can I solve this problem ?
EMilio
bolson
Re: Nagios Core 4.1.2 and check_vmware_api.pl
Post by bolson »
Did you download VMware-vSphere-Perl-SDK-5.1.0-780721.x86_64.tar.gz? This error would suggest that you're either missing some dependency files or some perl libraries.
