CCM apply configuration sends nagiosxi into restart loop
nbritton
Post by nbritton »
When we update configuration in CCM and then click "apply configuration" nagios goes into a restart loop continuously for about 30 minutes. It appears to be linked to the restart_nagios_with_export.sh script and reconfigure_nagios.lock file. After about 30 minutes of continuous restarts where we see this script running and the lock file present, the lock will finally go away and nagios s running normally. Please help. Profile attached!
bolson
Re: CCM apply configuration sends nagiosxi into restart loop
Post by bolson »
Please run this from the command line and post your result:
