Hello team,
Kindly ask, could You please renew the pdf file in the following article of knowledge base - https://support.nagios.com/kb/article/n ... lient.html
Currently 404 not found.
Regards.
MD
nagios client massive deployment sccm
Re: nagios client massive deployment sccm
I've attached a copy found on waybackmachine.
Though it's likely that the documentation was deprecated since it's referencing some pretty old versions of everything.
- Mass_Deploy_NSClient_Plus_Plus.pdf
- (1.06 MiB) Downloaded 400 times
bolson
Thank you mcapra. mdomanski, if you don't have any additional questions, may we close this thread?
Thanks @mcapramcapra wrote:I've attached a copy found on waybackmachine.
We had decommissioned the article we had, because as it was so old, and was believed to be no longer functioning
thanks for update! topic should be closed
