No data was received from host!
robert.anderko
Hi all,
i have problem with obtaining data from one Windows server. NRPE part works fine, but nsclient not works. I trying install new version of nslient, but same issue.
tested/not working with:
nsclient 0.4.4.19 & nsclient 0.5.0.62
/usr/local/nagios/libexec/check_nt -H XXX.XXX.XXX.XXX -s "" -p 12489 -v CPULOAD -l 5,90,95
could not fetch information from server
in log file:
2017-08-10 20:05:57: debug:c:\source\master\include\nrpe/server/protocol.hpp:72: Accepting connection from: XXX.XXX.XXX.XXX, count=1
2017-08-10 20:05:57: debug:c:\source\master\include\compat.cpp:21: Created command: warn=used>=85% crit=used>=95% show-all "detail-syntax=%(type): Total: %(size) - Used: %(used) (%(used_pct)%) - Free: %(free) (%(free_pct)%)" type=physical
NRPE part returning data without problems.
thx for any idea
in log file:
thx for any idea
bolson
Re: No data was received from host!
Hello Robert,
Open c:\program files\nsclient++\nsclient.ini and make sure your Nagios server's ip address is in the allowed hosts directive.
From the command line on the Nagios server, run:
And post the result.
telnet windows-box-ip 12489-
robert.anderko
yes, parameter is configured
results:
[root@xxx~]# telnet windows.box 12489
Trying windows.box...
Connected to windows.box.
Escape character is '^]'.
telnet> ^C
results:
telnet> ^C
bolson
Run this from the command line on the Nagios server:
/usr/local/nagios/libexec/check_nt -H <ip_address> -p 12489 -v MEMUSE-
robert.anderko
/usr/local/nagios/libexec/check_nt -H 10.82.186.11 -p 12489 -v MEMUSE
but NRPE
/usr/local/nagios/libexec/check_nrpe -H 10.82.186.11 -p 5666 -c CheckMEM -a MaxWarn=85% MaxCrit=95% ShowAll type=physical
physical: Total: 93.749GB - Used: 18.033GB (19%) - Free: 75.716GB (80%)|'physical'=18.03263GB;79.68671;89.06162;0;93.74908 'physical %'=19%;85;95;0;100
but NRPE
bolson
Please attach the nsclient.log file from c:\program files\nsclient++
robert.anderko
logfile
robert.anderko
error:c:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:396: Failed to find wrapping for type: exe
PS C:\Program Files\NSClient++> ./nscp.exe client --query alias_cpu
E ext-script Failed to find wrapping for type: exe
E w32system Failed to get Mutex for: cput
c:\source\nscp\modules\CheckSystem\pdh_thread.cpp:280
OK: CPU load is ok.|
This issue is reported in couple of servers and nsclient works fine. I think not related to reported issue
The check_nt and the check_nrpe plugins use separate settings in the nsclient.ini file so to troubleshoot this issue, we would have to see your nsclient.ini file from that server.
Can you post it here?
Also, make sure the firewall allows inbound traffic on port 12489 on that server.
bolson
Please run the following command from the Nagios server and post the output. We want to verify that this isn't a firewall issue.
nmap <windows-box-ip> -p T:12489
