how can i enable audio alert on nagios xi
ubridge6984
Post by ubridge6984 »
I am using nagios core with audio alert for 8 years
I want to use nagios xi
So i installed nagios xi but i found that i can't hear audio alert ( i can use audio alert on nagios core with changing cgi.cfg)
How can i enable audio alert on nagios xi?
tacolover101
Re: how can i enable audio alert on nagios xi
Post by tacolover101 »
i don't think this exists currently, but i'm sure it could be a feature request made from AJAX calls. the hard part may be keeping it persistent through pages, but then again it could probably be embedded in the outter frame.
ssax
Dreams In Code
Post by ssax »
As a workaround, can you set it up the same way and then try http://YOURXISERVER/nagios instead of http://YOURXISERVER/nagiosxi?
Let us know the results.
Thank you
