Nagios Core 4.1.2 , NagiosQL 3.2.0 and Write date
emi65
Post by emi65 »
Hi expert
I'm using nagiosQL to manage Nagios configuration
I like to automate the WRITE operation (write data from Mysql NagiosQL DB to config nagios files)
because I create some scripts that read the services present on server and Insert them in nagios
Some one know how write data using NAGIOSQL API from a bash script ?
Emilio
tacolover101
Re: Nagios Core 4.1.2 , NagiosQL 3.2.0 and Write date
Post by tacolover101 »
i don't know the QL interface directly, but if you're looking to make calls from the CLI - you probably just need to extract calls and make them using CURL.
We do not maintain the NagiosQL project internally and I don't believe what you describe exists.
