We are using nagiosxi with active directory enabled.
Is it possible to configure nagvis to not require a login after logging into XI?
Nagios and nagvis single sign on
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Re: Nagios and nagvis single sign on
This is coming in 5.5 version of Nagios XI when it is released.
Thank you you can lock it
Proudly running:
Nagios Fusion
Nagios Fusion
