Hi Team,
I am using a snmp memory check command to check the Memory utilization in percentage for windows but unfortunately it stopped working in few servers and I am unable to find where is the exact issue.
Can anyone help me in fixing this and the error i am getting is UNKNOWN and the nagios IP's series is xx.xx.0.xx (nagios core) and i am monitoring server series is xx.xx.1.xx and I am able to ping these server as well.
Once check and help in fixing this and I have attached the screenshot and libexe file which i am using for memory utilization
Nagios Core Memory Concern
- raise.zip
- (69.54 KiB) Downloaded 168 times
bolson
Re: Nagios Core Memory Concern
Please execute the plugin script from the command line and post the command syntax and the result.
Thank you!
Thank you!
Please find the attachment of libexe file executed in the command line and also the ping response of the server from nagios server
bolson
Please post the syntax of your check_snmp_memory command as you're executing from the command line.
