Hii team,
I have installed nagios NA , it was working fine but after some time when i "m giving login credentials it showing a web page that "The action you have requested is not allowed".
I have restarted services (NagiosNA , mysqld, httpd)
I have cleared cache of my browser.
Please suggest what to do.
as web page is running bcz login page is opening but when i"m giving credentials its giving attached error.
Not able to login
progressive.nagiosXI
Not able to login
Re: Not able to login
Do you have any sort of web proxy or firewall in-place that might be modifying or blocking certain requests?
No we don't have any thts why i"m asking help from you
Try this to see if it fixes the error.
Edit this file on the NNA server
Change the following from (Line 296)
to
Save the file and restart Apache by running
Clear your browsers cache and see if you can login to NNA's GUI.
/var/www/html/nagiosna/application/config/config.phpCode: Select all
$config['csrf_protection'] = TRUE;Code: Select all
$config['csrf_protection'] = FALSE;Code: Select all
service httpd restart Be sure to check out our Knowledgebase for helpful articles and solutions!
