UNable to login using AD account
sgiworks
Post by sgiworks »
Hello Team,
We have enabled LDAP authentication and were able to add the users and grant them access, however the users are unable to login.
Error Message: Could not get user. Specified ID may be wrong.
Regards,
Swapnil
cdienger
Re: UNable to login using AD account
Post by cdienger »
Please provide the ouptput of the following commands:
curl -XGET 'http://localhost:9200/nagioslogserver/user/_search?pretty'
curl -XGET 'http://localhost:9200/nagioslogserver/cf_option/auth_servers/?pretty'
curl -XGET 'http://localhost:9200/_cluster/health?level=indices&pretty'
The first two commands may have some sensitive info regarding the AD settings. Please PM these to me.
sgiworks
Post by sgiworks »
cdienger
Post by cdienger »
Config appears good. Use https://support.nagios.com/kb/article/a ... ation.html to enable authentication debugging and provide the error_log.
sgiworks
Post by sgiworks »
I have enabled the logs, but where can I find the logs so that I can share it with you?
cdienger
Post by cdienger »
According to the doc you should be able to see errors logged to /var/log/httpd/error_log. Please provide this file.
sgiworks
Post by sgiworks »
error_log attached for further investigation and resolution
cdienger
Post by cdienger »
Unfortunately nothing was logged. Please send an email to [email protected] referencing this case number and we can open a ticket to take a closer look.
sgiworks
Post by sgiworks »
I just tried creating a new local user, but even that user is unable to login. What could be the problem here?
I really want to get LDAP authentication working ASAP.
Post by mcapra »
cdienger wrote:According to the doc you should be able to see errors logged to /var/log/httpd/error_log.
Alternatively, if it's a data write/read issue within ElasticSearch you might see something in the ElasticSearch log (/var/log/elasticsearch/*.log)
