service_check_timeout_state issue
delboy1966
Post by delboy1966 »
Hi All
Again I am in search of the knowledge of the forum users.
Scenario:
Nagios 4.3.2
Worker nodes running mod_gearman-2-2.1.5-1
We have service_check_timeout_state in the nagios.cfg file to "u" for Unknown.
However when a service check on a worker node times out it goes Critical with the message "Service Check Timed Out On Worker: nag02"
When a service check timeouts on the main Nagios box it goes to Unknown as expected.
My question is do the worker nodes ignore the setting for service check timeouts from the Nagios config file or am I not doing some in the mod_gearman config files to tell it to do the same?
Tony
cdienger
Re: service_check_timeout_state issue
Post by cdienger »
Check out the steps in https://support.nagios.com/forum/viewto ... =7&t=45062 and let me know if that resolve the problem.
delboy1966
Once again an answer that resolves the problem.
The config option wasn't there so I added it, reload mod_gearmans2_worker and forced a check.
It came back as Unknown.
Tony
