Graph explorer and multistacked graph explorer intervals
Unigarant
Post by Unigarant »
We use graph explorer and multistacked graph explorer to troubleshoot issues.
The standard graph explorer shows the checks we run every minute in 1 minute intervals. The multistacked version uses 5 minute intervals, for the same 1 minute checks.
Is there some way we can get the multistacked graph explorer to use 1 minute intervals? Right now we might se a spike on graph explorer, but when we investigate and try to correlate it to other graphs the spike will not show or be less pronounced because of the 5 minute intervals...
cdienger
Re: Graph explorer and multistacked graph explorer intervals
Post by cdienger »
We'll be filing a feature request to show the stacked graphs in 1 minute intervals since this would require changes on the backend.
feature request #12369
Francesco
Post by Francesco »
We had this issue too.
Are there any update regarding feature request #12369 ?
Thank you
cdienger
Post by cdienger »
It is currently a feature request with no set date for release.
