Hi
I would like to know which process or installation process create s the map.php file.
Becuase I began from crash, installed nagios in some "clean"unbuntu.
Everything is working fine, but I had to copy the file map.php to the new installation ( still donest work in the new instalation, I can not see the map ( only the legacy map, legacy map work perfectly) , but when I try to see the new Map , the process is spinning forever).
I was follwin gstep by step the process: In my original installation the map.php is there and works just perfect.
\But in the new installation,. the map.php is not there and I have not idea why the file map.php is not there.
I just skip some step?
Who created and puts the file map.php in /usr/local/nagios/ share ?
**** Note:n my case , the installation path is /usr/local/nagios
Any idea o suggestion would be highly appreciate.
Regards
Yolanda
Who creates and put the file map.php in nagios_path/share
Re: Who creates and put the file map.php in nagios_path/s
Are you installing from source?
Are the versions the exact same from one machine to the next?
This is likely the problem if you have a newer nagios install that had the file, and then try to add the file to a system that was installed from a repository that didn't have the file it will not work.
