Folks,
I currently separate the logs I receive on specific ports. Each entry represents a customer.
I would like to know if it is possible to put a TAG (Type) in the inputs of each port. This TAG would be unique for each
Port, containing the company name of this client, field that would like to use it for query.
Thank you all.
Inputs with specific TAG(Type)
Re: Inputs with specific TAG(Type)
That will be okay. The default config even has a couple examples demonstrating this:
and
tcp {
type => 'import_raw'
tags => 'import_raw'
port => 2056
tcp {
type => 'import_json'
tags => 'import_json'
port => 2057
codec => json
carlos.mangini
Excellent!
Thanks for the fast feedback!
