Applying Configuration Failure
blariv
Post by blariv »
I have a strange issue. whenever we apply the config it will fail, however when you check the config snapshots it does not show the one you just ran w/ the error.
An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
Nagios XI Version : 2012R2.7
nagiosxi.hasbro.com 2.6.32-573.26.1.el6.x86_64 x86_64
CentOS release 6.7 (Final)
Brian
bolson
Re: Applying Configuration Failure
Post by bolson »
Hello blariv,
Please run the following from the command line of your Nagios Core server and post the result:
Thank you!
blariv
Post by blariv »
results
Total Warnings: 24
Total Errors: 0
Can you run the following and post the results
chage -l nagios
chage -l apache
sestatus
ls -la /usr/local/nagiosxi/scripts/nagiosql*
Also, start a running tail on the cmdsubsys.log, and redirect the output to a text file:
tail -f /usr/local/nagiosxi/var/cmdsubsys.log &> /tmp/debug.txt
While the tail is running, apply configuration in the web UI. When this is done (you see an error in the web UI), go back to the terminal, and stop the tail by pressing "Ctrl + c". Next, post the "debug.txt" file that was generated in the "/tmp" directory.
blariv
Post by blariv »
well you wont believe it, its working fine now. I had just run the write config files and then the apply config worked.
lock it up and thank you
blariv wrote:well you wont believe it, its working fine now. I had just run the write config files and then the apply config worked.
Glad to be of assistance!
