Service definition duplication by configuration files import
Hi all,
I'm trying to import an existing configuration into a new installation of Nagios XI (this is a test environment with a manual install of Nagios XI over a CentOS 7 host).
I noticed that, importing the same files twice or more, service definitions get duplicated. It seems that only services are affected
(no host, contact or command definition duplication, for instance, even if I re-import all the files every time).
I thought that importing the same definitions twice or more would not duplicate entries (I vaguely remember doing
this with NagioSQL a while ago, I'm pretty sure there were no duplications, and I could keep importing the same files until the
whole import process was OK). "Overwrite Database" is checked.
Since, in production environment, I will need to perform configuration import in chunks, I cannot ensure I will
import a service definition just once, and I won't be able to scratch the config and restart, as I'm doing in test environment,
so I could en up having duplicates and needing to manage them by hand.
Is there a way to avoid duplicating service definitions, or to quickly get rid of the duplicates?
Giacomo
Giacomo
Re: Service definition duplication by configuration files im
Are you following this doc and using the import prep tool?
Thanks for the prompt reply.
Yes, I am:
Importing all the files under /usr/local/nagios/etc/conf.preimport after I did:
gives immediately some duplicates:
If I repeat the import process, PING still appears 4 times, Uptime 2 times (as above), and there are 7 services which appear 2 times:
(I hid some service names). Importing the files again inserts another instance of those services:
I could try cleaning configuration files before importing them and double-check to ensure there are no duplicate service
definitions before importing; after all, the configuration is not that big, and not all services are duplicated, just those above
(on a total of 94 services); but I'm still puzzled by the fact that those services get inserted multiple times.
Is there anything I can check to see if they're somewhat "special"?
Thanks.
Yes, I am:
[root@localhost conf.preimport]# for file in ../conf.orig/nagios/*cfg ../conf.orig/nagios/objects/*cfg; do echo $file; php /usr/local/nagiosxi/tools/xiprepimport.php $file || break; done
[root@localhost conf.preimport]# mkdir /usr/local/nagios/etc/conf.preimport
[root@localhost conf.preimport]# cp * /usr/local/nagios/etc/conf.preimport/
[root@localhost conf.preimport]# cd /usr/local/nagiosxi/scripts/
[root@localhost scripts]# ./restore_defaults.sh
[root@localhost scripts]# mysql -pnagiosxi nagiosql
MariaDB [nagiosql]> select service_description, count(*) c from tbl_service group by service_description having c > 1;
| service_description | c |
| PING | 4 |
| Uptime | 2 |
2 rows in set (0.00 sec)
MariaDB [nagiosql]>
| C:\ Drive Space | 2 |
| Check LDAP Domain Controller | 2 |
| Check_XXXXX | 2 |
| KKKKKKK | 2 |
| NNNNNN | 2 |
| VVVVVVV | 2 |
| GGGGGG | 2 |
| PING | 4 |
| Uptime | 2 |
9 rows in set (0.00 sec)
| C:\ Drive Space | 3 |
| Check LDAP Domain Controller | 3 |
| Check_url_XXXXX | 3 |
| KKKKKKK | 3 |
| NNNNNN | 3 |
| VVVVVVV | 3 |
| GGGGGG | 3 |
| PING | 4 |
| Uptime | 2 |
Thanks.
This is logical because you may have the same service names on multiple hosts.
looking at the DB isn't where you should be looking, it's in the CCM.
Follow the instructions on the import order in the "Import Config Files" section and you should do fine
Thanks for you reply. I think the problem is not completely clear, I'll try to clarify.
An example: I have one configuration file, localhost.cfg, with this content:
Notice it has one "PING" service, among the others. If I keep importing this file more and more times, no service gets duplicated
inside the db.
I have one other configuration file: linksys-srw224p.cfg:
It has one "PING" service, like localhost, but the check command is different. I understand that the two different
checks must be inserted in DB, so I must find one line for each service: one for localhost, the other for linksys-srw224p.
BUT, if I keep importing the linksys-srw224p.cfg, each time I get ANOTHER line for the PING service
(and JUST for that: the other three services are not duplicated).
To be clear, this happened after I imported the file 3 times, but just for the PING service:
As you can see, localhost appears just once (even if keep importing localhost.cfg more and more and more...)
while linksys-srw224p is there 3 times.
The result is that, when generating configuration files, the service is inserted 3 times in the configuration file:
I'm puzzled, because I don't see what could possibly mess with the configuration.
use linux-server
host_name localhost
alias localhost
address 127.0.0.1
define hostgroup{
hostgroup_name linux-servers
alias Linux Servers
members localhost
use local-service
host_name localhost
service_description PING
check_command check_ping!100.0,20%!500.0,60%
use local-service
host_name localhost
service_description Root Partition
check_command check_local_disk!20%!10%!/
use local-service
host_name localhost
service_description Current Users
check_command check_local_users!20!50
use local-service
host_name localhost
service_description Total Processes
check_command check_local_procs!250!400!RSZDT
use local-service
host_name localhost
service_description Current Load
check_command check_local_load!5.0,4.0,3.0!10.0,6.0,4.0
use local-service
host_name localhost
service_description Swap Usage
check_command check_local_swap!20!10
use local-service
host_name localhost
service_description SSH
check_command check_ssh
notifications_enabled 0
use local-service
host_name localhost
service_description HTTP
check_command check_http
inside the db.
check_command check_ping!200.0,20%!600.0,60%
normal_check_interval 5
retry_check_interval 1
host_name linksys-srw224p
service_description Uptime
check_command check_snmp!-C public -o sysUpTime.0
service_description Port 1 Link Status
check_command check_snmp!-C public -o ifOperStatus.1 -r 1 -m RFC1213-MIB
service_description Port 1 Bandwidth Usage
check_command check_local_mrtgtraf!/var/lib/mrtg/192.168.1.253_1.log!AVG!1000000,1000000!5000000,5000000!10
MariaDB [nagiosql]> select id, config_name, host_name, hostgroup_name, service_description, check_command, last_modified from tbl_service where service_description = 'PING';
| id | config_name | host_name | hostgroup_name | service_description | check_command | last_modified |
| 1 | localhost | 1 | 0 | PING | 17!100.0,20%!500.0,60% | 2017-08-24 13:39:59 |
| 68 | linksys-srw224p | 0 | 0 | PING | 17!200.0,20%!600.0,60% | 2017-08-24 13:39:21 |
| 87 | linksys-srw224p | 0 | 0 | PING | 17!200.0,20%!600.0,60% | 2017-08-24 13:39:59 |
| 89 | linksys-srw224p | 0 | 0 | PING | 17!200.0,20%!600.0,60% | 2017-08-24 13:48:26 |
# Service configuration file
# Created by: Nagios Core Config Manager 2.6.8
# Date: 2017-08-24 14:11:02
# Version: Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
check_interval 5
retry_interval 1
register 1
check_interval 5
retry_interval 1
register 1
check_interval 5
retry_interval 1
register 1
register 1
register 1
register 1
# END OF FILE
Are you sure you ran these files through the config prep tool? Because these are usually caught in this tool.
Also in your example for linksys-srw224p.cfg you should this definition right at the top
There isn't a host_name defined for this service.
}Re: Service definition duplication by configuration files im
Ok, that was my fault, I fixed it.
So far, PING and Uptime do not get duplicated anymore (PING was duplicated apparently because I accidentally deleted the host_name directive from the configuration, as you pointed out).
For the other services, I noticed that they were the only services specified with multiple hosts on the same host_name line, i.e.:
I removed the configuration of those services from the _multiple_hosts.cfg file and split them manually into multiple service definitions:
and so on. Now when I import the full configuration I have something like this:
that is, one service for each host (is it the intended behaviour?). This time, even if I import the configuration multiple times, they do not get duplicated (i.e. the numbers remain the same).
The only service which can still be duplicated is this:
which, oddly, is defined just for one host. But I think the situation is better. Now the only warnings I get are for the "C:\ Drive Space",
if I duplicate it:
Does this make any sense?
Thanks.
host_name host1, host2, host3
host_name host1
service_description XXXXXXX
use myTemplate
check_command XXXXXXX_check_command
host_name host2
use myTemplate
| Check LDAP Domain Controller | 12 |
| Check_XXXX | 4 |
| YYYYY | 3 |
| ZZZZZZ | 3 |
| KKKKK | 10 |
| VVVVV | 50 |
| PING | 4 |
| Uptime | 2 |
host_name hostW
service_description C:\ Drive Space
check_command check_nt!USEDDISKSPACE!-l c -w 80 -c 90
if I duplicate it:
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'winserver' (config file '/usr/local/nagios/etc/services/hostW.cfg', starting on line 24)
Warning: Duplicate definition found for service 'C:\ Drive Space' on host 'winserver' (config file '/usr/local/nagios/etc/services/hostW.cfg', starting on line 16)
Thanks.
This looks a lot better and as expected for all except the
C:\ Drive Space
I don't know why there would be 2 of these but you should be able to go to the services in the CCM select the "C:\ Drive Space" hostW from the config file drop down and remove the extra item
C:\ Drive Space
