Acknowledge issue
Phil.Pearce
Acknowledge issue
Ive just gone into an "latest alert" in nagios, Ive acknowledged the problem yet it doesnt acknowledge.
Any ideas on what this could be?
- tacolover101
Re: Acknowledge issue
check your SQL logs - is your DB crashed by any chance?
Phil.Pearce
dont think so, everything else seems to look ok
Can you run the following and post the output
tail /var/log/mysqld.log-
Phil.Pearce
170825 9:33:58 [Note] /usr/libexec/mysqld: Shutdown complete
170825 09:33:58 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
170825 09:34:10 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
170825 9:34:10 InnoDB: Initializing buffer pool, size = 8.0M
170825 9:34:10 InnoDB: Completed initialization of buffer pool
170825 9:34:10 InnoDB: Started; log sequence number 0 44233
170825 9:34:10 [Note] Event Scheduler: Loaded 0 events
170825 9:34:10 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.1.73' socket: '/var/lib/mysql/mysql.sock' port: 3306 Source distribution
I have also performed a DB repair just incase
So when you click Acknowledge on an issue it doesn't change on the service detail page?
If this is the case can we verify multiple nagios parent processes aren't running
ps-ef|grep bin/nagios-
Phil.Pearce
ps-ef |grep bin/nagios
-bash: ps-ef: command not found
ps -ef | grep bin/nagios
root 23574 8654 0 08:54 pts/0 00:00:00 grep bin/nagios
nagios 85206 1 0 Aug23 ? 00:25:31 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 85208 85206 0 Aug23 ? 00:01:50 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 85209 85206 0 Aug23 ? 00:01:49 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 85210 85206 0 Aug23 ? 00:01:49 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 85211 85206 0 Aug23 ? 00:01:51 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 85212 85206 0 Aug23 ? 00:01:51 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 85213 85206 0 Aug23 ? 00:01:49 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 85269 85206 0 Aug23 ? 00:00:18 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
That looks good. Sorry about missing the space
scottwilkerson wrote: So when you click Acknowledge on an issue it doesn't change on the service detail page?
Phil.Pearce
Nothing
I click acknowledge. Nothing happens.
If i click onto latest alerts instead of it saying "xx service is being handled", it still looks like an alert
Ok, if you click the link and nothing happens, I think you may have a javascript issue or something, you should see a box like this:
If you do not see this would it be possible to try a different browser?
We may need to perform a remote session, to do so you should open a ticket by sending an email to [email protected] referencing this thread
Thanks!
Thanks!
