Hello is there anyway of adding or modifying additionnal information to the "output message" field of the alterting function in nagioslogserver
Saleem
Modifying the "output message" of the alerting function
saleemthupsee
Saleem THUPSEE
Re: Modifying the "output message" of the alerting function
Which alert method are you trying to modify?
saleemthupsee
the NRDP alerting method, i would like to get a more meaningful message other than "XXX entries found" that I am sending to Nagiosxi.
I am would like the same thing to have output message set via the script alterting method
Saleem
Saleem
Saleem THUPSEE
saleemthupsee
I rectify my previous post, i would actually like to add some other output message other than XXX log entries found on the NDRP alter method, is there any other variable that can be set bor that purpose ?
Saleem THUPSEE
Currently this isn't possible but it is a feature request with task id #7424.
saleemthupsee
hello any idea of the ETA for this feature ?
Saleem THUPSEE
Not currently but general roadmap information or all products can always be found at www.nagios.com/roadmaps/
