Not sure if this is possible, but is there a way to change in bulk all the service checks with a 1/1 attempt (i.e. in the configuration of service -> When a potential problem is first detected)?
Do not presume this will offer any additional load to the application.
Rgds,
Matthew
Updating Attempts for all service checks
Re: Updating Attempts for all service checks
It is possible in Core Config Manager -> Tools -> Bulk Modification Tool
Change a single configuration option
set "Max check attempts" to 1
Select all services
Save
This should not cause any noticeable performance change.
Select all services
Save
Thank you scottwilkerson. This thread can be closed!
