Dynamic IP host monitoring
progressive.nagiosXI
Post by progressive.nagiosXI »
Hii,
How we can monitor any host whose IP is not static??
Please suggest
Re: Dynamic IP host monitoring
Post by mcapra »
Two options that come to mind:
Have the host submit passive checks to Nagios XI. NCPA and NSClient++ both have native options for passive checks.
Leverage a DNS record for the host.
tacolover101
Post by tacolover101 »
to add on to what @mcapra mentioned, a dynamics DNS provider such as dyndns or no-ip should work for this.
Post by dwhitfield »
With this we have some question,
1 - How do we monitor host up/down
2 - If agent stops giving data how do we get notified for the same ?
3 - if we are monitoring two host with agent and if the swap their IP with themselves How nagios going to identify that
1. Using DNS is the easiest from the nagios side
2. If you use DNS, then just use a normal active check.
3. https://exchange.nagios.org//directory/ ... IP/details talks about external IPs, but I don't see why you couldn't use it for internal IPs.
Setting up DNS really depends on your environment, but is outside of the scoop of support anyway. If you are in a Windows environment, https://technet.microsoft.com/en-us/lib ... s.11).aspx may be of some use.
