Monitoring Password expiry of Windows Server
hussaingany
Post by hussaingany »
Hello Everyone,
I wanted to monitor Password Expiry and user account's expiry of Windows server through Nagios. Thanks in advance for your kind support.
Regards,
Mohamed Hussain
tacolover101
Re: Monitoring Password expiry of Windows Server
Post by tacolover101 »
look through the Exchange to see if you can find a plugin - https://exchange.nagios.org/
Post by dwhitfield »
Are these active directory accounts? If so, it looks like https://exchange.nagios.org//directory/ ... ts/details will work for you. Don't worry about the fact that it says Nagios 3.x. That just means the developer only tested on that version. There's no reason to think it won't work on later versions.
