we have Nagiox XI version 5.4.4 VM machine ,we have a server "solairs 11" with large number of disks " SAN disks " and we need to monitor them as below command
[[email protected] ~]$ /usr/local/nagios/libexec/check_nrpe -H 10.x.x.x -t 180 -c check_iostat -a '-d c2t500009755807104Bd3 -w 80000,80000,500000,80000,80000,80000,50,50,50,50 -c 85000,85000,600000,85000,85000,85000,70,70,70,70 -p'
in order to set the configuration quickly and accurately we need to provide us with the method to edit to insert the needed information in bulk way from the back end of the Nagios using either commands line or scripts
thanks
bulk services
bashar.abed
- tacolover101
Re: bulk services
you could import a static configuration, use a wizard, copy configuration of a service, or use services with templates.
i'm guessing the -d is going to be unique each time though so you'll want to keep that in mind when you go through.
- Former Nagios Staff
Re: bulk services
Thanks @tacolover101!
OP, I think you'll find https://support.nagios.com/kb/article.php?id=539 useful. Please let us know if you have any questions about the document.
