Check MS SQL Stored Procedure
jkinning
Post by jkinning »
I am looking to leverage Nagios to run some stored procedures within MSSQL server. I found this plugin
https://exchange.nagios.org/directory/Plugins/Databases/SQLServer/check_mssql_sproc/details
which everytime I tried to run it I get "command not found" I discovered an updated version here
https://github.com/brunocantisano/check_mssql_sproc_parameters
but that too gave me the same message.
My question is there another or easier :D way to get Nagios to connect to an MS SQL server, run a stored procedure, and alert based on the results?
bolson
Re: Check MS SQL Stored Procedure
Post by bolson »
For check_mssql_sproc please share the syntax that you are using to execute the command.
jkinning
Post by jkinning »
./check_mssql_sproc_parameters.pl -H sqldev_digitallog,4000 -u DigitalLogNagios -P detak_22e -p "dbo.uspDgtlGetErrorLogs @DgtlLogMinutes = 999999, @DgtlLogSourceId = 16, @DgtlLogLevel = 4" -w 1 -c 2
Running this from the command line as the nagios user on the server. Once I get this working then I add it to the NagiosXI GUI.
Post by mcapra »
I can't even get check_mssql_sproc_parameters to connect to my SQL Server database:
[root@nagios libexec]# ./check_mssql_sproc_parameters.pl -H 1.1.1.1,1433 -d database -u username -P password -p "get_gpa_stats_all @calendarID=57" -w 1 -c 2
DBI connect('Driver={ODBC Driver 11 for SQL Server};SERVER=1.1.1.1,1433','username',...) failed: [unixODBC][Driver Manager]Data source name not found, and no default driver specified (SQL-IM002) at ./check_mssql_sproc_parameters.pl line 71.
Error: Unable to connect to MS-SQL database!
Just some thoughts from playing around with this totally unrelated to what may ultimately be the solution.
check_mssql claims to be able to handle stored procedures:
https://exchange.nagios.org/directory/P ... ql/details
EDIT: Nevermind all that PDO stuff I wrote earlier. This seems to work:
#!/usr/bin/php
<?php
  $dbh = new PDO("dblib:host=1.1.1.1;dbname=database", "username", "password");
  $sth = $dbh->prepare("EXEC get_gpa_stats_all @calendarID=57");
  $sth->execute();
  while($result = $sth->fetch(PDO::FETCH_ASSOC)) {
    var_dump($result);
I'll take a look at the implications for check_mssql if a solution isn't found by the time I'm out of meetings.
jkinning
Post by jkinning »
I tried the other one, original, one and get the same "command not found" message.
./check_mssql_sproc.pl -H sqldev_digitallog,4000 -u DigitalLogNagios -P detak_22e -p "dbo.uspDgtlGetErrorLogs @DgtlLogMinutes = 999999, @DgtlLogSourceId = 16, @DgtlLogLevel = 4" -w 1 -c 2
bolson
Post by bolson »
The error "Command not found" invariably means exactly what it says. Is check_mssql_sproc.pl in the directory from which you're running it?
jkinning
Post by jkinning »
Yes, I am running it from /usr/local/nagios/libexec
-rwxrwxr-x 1 apache nagios 144301 Nov 12 2014 check_mrtg
-rwxrwxr-x 1 apache nagios 145354 Nov 12 2014 check_mrtgtraf
-rwxrwxr-x 1 apache nagios 17546 Oct 4 2016 check_mssql
-rwxrwxr-x 1 apache nagios 14446 Oct 4 2016 check_mssql_database.py
-rwxrwxr-x 1 apache nagios 20473 Oct 4 2016 check_mssql_server.py
-rwxr-xr-x 1 apache apache 6746 Aug 28 10:45 check_mssql_sproc_parameters.pl
-rwxrwxrwx 1 apache apache 5400 Aug 28 10:11 check_mssql_sproc.pl
-rwxrwxr-x 1 apache nagios 190904 Nov 12 2014 check_mysql
-rwxrwxr-x 1 apache nagios 122024 Jun 15 2016 check_mysql_health
-rwxrwxr-x 1 apache nagios 175374 Nov 12 2014 check_mysql_query
-rwxrwxr-x 1 apache nagios 157438 Nov 12 2014 check_nagios
Post by mcapra »
You might also check the output of which perl executed from both root and the nagios user to make sure the script's shebang is pointing to the correct executable.
Also, you are using a MSSQL user and not Windows domain users correct?
jkinning
Post by jkinning »
[root@nagiosl1t ~]# which perl
/usr/bin/perl
[nagios@nagiosl1t libexec]$ which perl
/usr/bin/perl
Yes, I am using an AD service account with read rights to the MSSQL database.
