Ping is not enabled on Nagios Server and Remote Hosts , but service is running OK . How can i stop getting ping alerts as host is down and enable check_tcp -p 80 .
Tried Check_tcp -p 80 , but it brings the host UP in dashboard only for sometime then again it does down with ping alert.
asifkhan_007
Re: Ping is not enabled on Nagios Server and Remote Hosts
Are you changing the command for the host, or for the services?
Could you share the host/service configuration file for the services with the problems along with the commands configured for these?
