Hi All 'I really would appreciate a bit of help. I am finding information but none seems to work for me. I am using Nagios Core 4 to monitor some Windows Machines. THey have nsclient++ 0.5.0.62 installed. All my checks work except checking the size of a file. Here is my config below.
#Commands.cfg
command_name Check_Test
command_line $USER1$/check_nrpe3 -H $HOSTADDRESS$ -p 5666 -c check_files -n MinWarn=$ARG2$ MinCrit=$ARG1$ -a File="c://test//test.txt"
#Windows.cfg
host_name server_name
service_description Test.txt Filesize
check_command Check_Test!1K!2K
I am getting the error CHECK_NRPE: Invalid packet type received from server. Could anyone please help me figure out what I am doing wrong?
Regards
Check_Files
Re: Check_Files
Try the fix mentioned in the "Increasing NSClient++ Payload Length" section of this document:
https://support.nagios.com/kb/article/n ... ained.html
Alternatively, you could just use check_nrpe v2.
- Former Nagios Staff
Re: Check_Files
Thanks @mcapra!
If Matt's suggestion doesn't work for you, can you upload your NSClient.ini? Also, I will note that we don't officially support the .5 series of NSClient (although it should largely work, as you know.)
