can we monitor hosts who are having Dynamic IP's with Ngios Log Server???
If yes then,
1 -- If we are monitoring two hosts who have switched IP between them how Nagios Log server will differentiate between them.
Dynamic IP log monitoring
Re: Dynamic IP log monitoring
Yes, the hosts will be sending their logs. They also send their hostname/machine name defined on the server/workstation with most syslog or windows logs so you can use them to identify each workstation.abhi321jay wrote:Hi,
If yes then,
