New Install - unable to install
I am doing a fresh installation, and I am getting this error
tried the steps on the following link ==>
https://support.nagios.com/kb/article/e ... tions.html
but that doesnt seem to work
[root@usvanagiospxi2 nagiosxi]# ./fullinstall
Your system $PATH does not include /sbin and /usr/sbin. This is usually the result of installing GNOME rather than creating a clean system.
Adding /sbin and /usr/sbin to $PATH.
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS or RedHat. Do NOT use this on a system that has been tasked with other purposes or has an existing
install of Nagios Core. To create such a clean install you should have selected ONLY the 'Base' package in the OS installer.
Do you want to continue? [Y/n] Y
Proceeding with installation...
Checking MySQL credentials...
MySQL not yet installed - that's okay.
Running './0-repos'...
Configuring Repos...
Passed New Subscription Check
package centos-release is not installed
Unable to locate SystemId file. Is this system registered?
ERROR: Please add the 'Optional' channel to your Red Hat systems subscriptions.
You can do so in the Redhat Network web interface or using the rhn-channel command.
or, install the yum-utils package and use the following command:
yum-config-manager --enable rhel-7-server-optional-rpms
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-repos'
RESULT=1
INSTALLATION ERROR!
Re: New Install - unable to install
The script is failing at:
What is the output of:
yum repolist all | grep optional-rpms | grep -qF enabledCode: Select all
yum repolist allAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
I got that working. I was able to install Nagios. I did a restore, but the problem I am seeing now is that the monitoring engine doesn't seem to be running
everything seems green.
I am using Mod_gearman, and mod_gearmand is running including the worker.
I dont see jobs running.
I tried disableling mod_gearman module from the nagios.cfg but I see the same result. So mod_gearman doesnt seem to be creating the problem
What data are you seeing in the nagios.log when you restart the nagios service?
No Errors
what I notice is that when I stop and start nagios. I see stuff flowing. I see JOBs running, but then all stops. but again, everything seems to be running, and I dont see anything on the logs. i.e. nagios.log, mysql, ewtc
[1504809807] Caught SIGTERM, shutting down...
[1504809819] Caught SIGTERM, shutting down...
[1504810126] Nagios 4.2.4 starting... (PID=27300)
[1504810126] Local time is Thu Sep 07 14:48:46 EDT 2017
[1504810126] LOG VERSION: 2.0
[1504810126] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1504810126] qh: core query handler registered
[1504810126] nerd: Channel hostchecks registered successfully
[1504810126] nerd: Channel servicechecks registered successfully
[1504810126] nerd: Channel opathchecks registered successfully
[1504810126] nerd: Fully initialized and ready to rock!
[1504810126] wproc: Successfully registered manager as @wproc with query handler
[1504810126] wproc: Registry request: name=Core Worker 27302;pid=27302
[1504810126] wproc: Registry request: name=Core Worker 27303;pid=27303
[1504810126] wproc: Registry request: name=Core Worker 27304;pid=27304
[1504810126] wproc: Registry request: name=Core Worker 27305;pid=27305
[1504810126] mod_gearman: initialized version 2.1.1 (libgearman 0.33)
[1504810126] Event broker module '/usr/lib64/mod_gearman2/mod_gearman2.o' initialized successfully.
[1504810126] ndomod: NDOMOD 2.1.2 (11-14-2016) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
[1504810126] ndomod: Successfully connected to data sink. 0 queued items to flush.
[1504810126] ndomod registered for process data
[1504810126] ndomod registered for log data'
[1504810126] ndomod registered for system command data'
[1504810126] ndomod registered for event handler data'
[1504810126] ndomod registered for notification data'
[1504810126] ndomod registered for comment data'
[1504810126] ndomod registered for downtime data'
[1504810126] ndomod registered for flapping data'
[1504810126] ndomod registered for program status data'
[1504810126] ndomod registered for host status data'
[1504810126] ndomod registered for service status data'
[1504810126] ndomod registered for adaptive program data'
[1504810126] ndomod registered for adaptive host data'
[1504810126] ndomod registered for adaptive service data'
[1504810126] ndomod registered for external command data'
[1504810126] ndomod registered for aggregated status data'
[1504810126] ndomod registered for retention data'
[1504810126] ndomod registered for contact data'
[1504810126] ndomod registered for contact notification data'
[1504810126] ndomod registered for acknowledgement data'
[1504810126] ndomod registered for state change data'
[1504810126] ndomod registered for contact status data'
[1504810126] ndomod registered for adaptive contact data'
[1504810126] Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
This is odd that this is happening twice. can you share your nagios.cfg ?bosecorp wrote:[1504810126] mod_gearman: initialized version 2.1.1 (libgearman 0.33)
good catch
I had these lines twice. at the top and bottom
broker_module=/usr/lib64/mod_gearman2/mod_gearman2.o config=/etc/mod_gearman2/module.conf eventhandler=no
removed the line, but unfortunately I still see the issue
restarting Nagios seems to help for few minutes. I see jobs running in garman_top2, then after few minutes everything stops.
Is it possible to comment out the other mod_gearman line and run the checks locally to verify it's not a problem with your version of mod_gearman?
I tried that already. that was one of the first things a I did
I meant so neither are running, just Nagios Core with no mod_gearmanbosecorp wrote:I tried that already. that was one of the first things a I did
Also can you post the output of the following
ps -ef|grep bin/nagios
