I am configuring monitoring. I have couple of queries:
1. Port 12489-TCP required for NSClient++, it is from Nagios server to Windows node or Windows Node to Nagios server or both.
2. Similarly for NRPE we need 5666-TCP on which direction.
3. For check_mssql, we need 1433-TCP or check_nt can call check_mssql.
Thanks.
Need to understand the port requirements
nitin.gupta111
Re: Need to understand the port requirements
Open on the Windows nodenitin.gupta111 wrote:1. Port 12489-TCP required for NSClient++, it is from Nagios server to Windows node or Windows Node to Nagios server or both.
Open on the Windows nodenitin.gupta111 wrote:2. Similarly for NRPE we need 5666-TCP on which direction.
Open on the Windows node, OR you would have to write a custom plugin to allow check_nt or check_nrpe to install on the Windows server that would make the connectionnitin.gupta111 wrote:3. For check_mssql, we need 1433-TCP or check_nt can call check_mssql.
nitin.gupta111
It is OK.
I dont see how to lock out the ticket. Please close the same.
