Hi Support,
I got message when I adding server windows monitoring "Password contains invalid characters." in agent password field. How can I use a "@" character? it's possible to skip this check? because my client they use a "@". and they have Nagios core isn't a problem with more 100 nodes by Nagios core. Now I have a poc Nagios XI and they won't happy to change an old password.
Please advise.
Thank you.
Use special character "@" in nsclient?
- tacolover101
Re: Use special character "@" in nsclient?
you may need to encapsulate the variable in single quotes, such as 'p@ssword'. if it's working in Core fine, I assume it's just manipulation somewhere.
the other option is placing it in the resources file - https://assets.nagios.com/downloads/nag ... Macros.pdf
Thanks @tacolover101 for the help.
I took a look at the wizard and it considers the @ as a special character and you would have to create a user macro and use that when running the wizard that the document @tacolover101 posted.
Once that is done, you should be able to run the wizard.
Thanks all, You're my heroes.
I did configured user macro and it's worked fine.
Thanks again.
Thanks again.
- tacolover101
no problemo.dimsum wrote:Thanks all, You're my heroes.
Thanks again.
