check_logs
epx998
check_logs
Post by epx998 »
Does the plugin check_logs support a query with more than one word? I am having an issue when I try to query "cannot open connect" as an example, the plugin thinks open is an option.
./check_nrpe -H my.host.com -c check_log -a /path/to/dummy/log/error.log /path/to/dummy/log/error.log.nagios "Cannot open connection”
I get the error, open is an invalid option;
Unknown argument: open
Usage: check_log -F logfile -O oldlog -q query
Usage: check_log --help
Usage: check_log --version
Ideas?
jsmurphy
Re: check_logs
Post by jsmurphy »
Are you able to also post the command definition from your NRPE config?
