Email Notification Not Working.
rameshonline81
Post by rameshonline81 »
Hello Everyone,
We have installed Nagios Core 4.2.0 and for some reason our emails notifications are not working. It was working until 3 days ago however post migration ( now that everything is in production) email notification are not working.
We are using mutt in order to send emails.
If I try to run this command
echo " Test" | /usr/bin/mutt -s "test" myemailaddress
I am able to receive email this way.
However email sent from Nagios are not coming in.
Contact.cfg
define contact{
        contact_name                    nagiosadmin             ; Short name of user
        use                             generic-contact         ; Inherit default values from generic-contact template (defined above)
        alias                           Nagios Admin            ; Full name of user
        email                           myemailaddress   ; <<***** CHANGE THIS TO YOUR EMAIL ADDRESS ******
Output of /var/log/messages
Sep  4 17:42:27 sdlmonitor2 nagios: SERVICE NOTIFICATION: nagiosadmin;18.11;Logged-In Users;WARNING;notify-service-by-email;USERS WARNING - 8 users currently logged in
Sep  4 17:43:27 sdlmonitor2 nagios: Warning: Return code of 127 for check of service 'HTTP' on host 'localhost' was out of bounds. Make sure the plugin you're trying to run actually exists.
Sep  4 17:45:57 sdlmonitor2 nagios: SERVICE NOTIFICATION: nagiosadmin;148.12;check_RELIANCE;CRITICAL;notify-service-by-email;CHECK_NRPE: Socket timeout after 10 seconds.
Sep  4 17:47:27 sdlmonitor2 nagios: SERVICE NOTIFICATION: nagiosadmin;18.11;Logged-In Users;WARNING;notify-service-by-email;USERS WARNING - 8 users currently logged in
Sep  4 17:48:27 sdlmonitor2 nagios: Warning: Return code of 127 for check of service 'HTTP' on host 'localhost' was out of bounds. Make sure the plugin you're trying to run actually exists.
/var/log/maillog is empty.
Any help would be much appreciated.
Ramesh Kumar
Re: Email Notification Not Working.
We would need to see the generic-contact template configuration, and if it hasn't been changed form the defaults the commands for
notify-host-by-email
These are likely what need to be changed to use the /usr/bin/mutt command
Then nagios restarted
DiegoAnjos
Post by DiegoAnjos »
Check if the path on commands.cfg is correct:
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/mailx -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
As far as I know, this path can vary depending on which distribution you are using.
DiegoAnjos wrote:Check if the path on commands.cfg is correct:
Right I think the OP wants to replace /usr/bin/mailx -s with /usr/bin/mutt -s
