When I install Nagios Core or NRPE via the rpm, it'll install with the default username nagios and group nagios.
I'd like to do the installation using different username/group. Is there a way to change them after I have installed
them using yum install?
If I cannot do that, if I want to use my own username/group, do I need to install Nagios core and NRPE from source
using my own username/group and then rpmbuild my own pkg if I want to use that pkg on other systems?
Thanks!
username/group change post rpm installation
Re: username/group change post rpm installation
No they are built into the RPMyomiko wrote:I'd like to do the installation using different username/group. Is there a way to change them after I have installed
You can built them from source on each server you need to do this, passing the custom user/group into the ./configure scriptyomiko wrote:If I cannot do that, if I want to use my own username/group, do I need to install Nagios core and NRPE from source
OR if familiar with making a custom RPM, yes, you can create a spec file with your customization, and create RPM's for each distribution that accepts RPMs to install packages.
- tacolover101
i believe you'll have to compile from source because the RPM's are preset.
Either way you would want to remove the existing installed RPM'stacolover101 wrote:i believe you'll have to compile from source because the RPM's are preset.
