Submit NRDP with Curl
spurrellian
Post by spurrellian »
I'm trying to send a passive check to my nagios host where the results has a space in it
curl -X POST -L 'http://nagios-live/nrdp?cmd=submitcmd&token=****&command=PROCESS_SERVICE_CHECK_RESULT;wxapsdpoc03;SQL_Daily_1;1;Backup Failed' --insecure
When it displays in Nagios it misses off " Failed" and just displays the word Backup
Can anyone help with the syntax?
Paul
Paul S - Using Nagios XI, Network Analyzer, Log Server
Re: Submit NRDP with Curl
You should replace all spaces with %20 as that is the URL-encoding of the space character - https://www.w3schools.com/tags/ref_urlencode.asp
spurrellian
I tried with %20 and it didnt work. but using + did
You can close the call
Ahh, yea my mistake. I think %20 would only work if the curl command was in double-quotes.
At any rate, glad to (sort of) help!
